RV.Net Open Roads Forum: Hybrid Travel Trailers: tire is wearing on the inside
Open Roads Forum  >  Hybrid Travel Trailers
 > tire is wearing on the inside
Hybrid Travel Trailers Related Tips
05Cub
New York
Posted: 10/20/09 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
Here is my 2 cents worth on this.
Chuck_S wrote:
Balancing trailer tires us usually a fruitless exercise and has as much potential to make them worse as better.
I don't agree with this
Simple reason is that hole in the center of an automobile wheel is a centering hole, exactly in the center. Tire balancing machines are designed for automobile wheels and depend on this being exactly in the center.
On trailer wheels it's just a hole in the middle so the spindle can stick thru, maybe or maybe not in the center. If you can get your trailer wheels balanced on a spindle that uses the lug holes and not the kinda-in-the-center-hole you're good.
This doesn't make sense to me due to the fact that the center hole on the rim is not a randomly drilled hole, it is set to go over the spindle end (hub) that the brake drum is mounted to and there is very little clearance around the perimiter of this hole so the studs do not center the wheel,the brake hub does.
I have balanced many tires over the years standard and high performance and have always used the center hole type balancer and as long as the machine is properly calibrated have not had any problems. The machine I use is a snapon WB260A and has a good track record. I peersonally feel there is no reason not to balance a trailer tire, it does spin as fast or faster than a car tire, it unsprung weight and with trailers not having shocks there is no snubbing effect to stop an out of balance tire from bouncing.
Just my thoughts on this, feel free to fire back
If you notice new trailers you'll never see wheel weights on the rims. This is because they aren't balanced, nor do they need to be.
-- Chuck
4HPYCMPRS
Niagara Falls, Canada
Posted: 10/20/09 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
I had serious tire wear on my left front tire. Switched it with the spare and now I will invest in new tires in the spring. I also balanced all four at my shop .... I have a hub-mount style balancer. I then took all four tires to a friends' shop and re-checked the balance of all four tires with his lug-mount balancer..... only one wheel was out and it was only out 1/4 oz. Certainly not enough to worry about. I have aluminum wheels.
I have had my own automotive repair shop for 17 years now and have been in the industry for over 20 years. I am not claiming to be a know-it-all but ..... I do know that tire balance IS VERY IMPORTANT for cars, truck and trailers too ! ! ! There is only one reason most new trailers don't have balanced wheels and why the factory doesn't do it ? Simply $ $ $ $ . Any tire that "vibrates" while going down the road is going to have a significant amount of "bounce" and with bounce comes pre-mature wear. JMO.
So, in short, if your wheels are off for any reason get 'em balanced ! ! ! ! !
Mark
'08 Chevy Avalanche LT3 6.0L (366hp) 4.10's
'06 Rockwood Roo 23SS. Equal-i-zer/P-3
'06 Honda EU3000iS TomTom ONE 130-S GPS.
Me ('71), DW ('70), DD ('01), DD ('04).
A wiseman once said "GIT-R-DONE"
'09 nights camped- 30
CAMPING PICS & MODS
johny_maple
Brantford, ON.
Posted: 10/23/09 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
Early on, our tires wore away on the inside. I would then have them reversed to wear away on the good side. That still left the centre looking like new. The bottom line? Incorrect axle camber. We've not had a tire wear problem since replacing the axle.
j_m
Wile E Coyote
North west Ohio
Posted: 10/24/09 08:16am Link  |  Quote  |  Print  |  Notify Moderator
Many years ago I worked at a shop that did tire balancing .. we had several methods of doing it however the best way was on vehicle it was being used on. We had a tool that mounted on the outside of the wheel that had weights that could be moved as the tire was spinning. We jacked up the axle and applied a drive motor via pushing against the tire and spinning it very fast , then it was allowed to free wheel during balancing. Once we found how much weight and where to put it we removed the tool and added the weight. This is the way to get the tire / wheel / vehicle combination and make it smooth...BUT as soon as you pull the wheel/ tire assembly off that custom balance is gone.
aepowell
Sherman,TX.
Good Sam RV Club
Posted: 10/26/09 02:42am Link  |  Quote  |  Print  |  Notify Moderator
Its hard find a shop that does that these days
Anthony & Margie Powell
Sherman,Tx.
2001 Jayco Kiwi 23B
2000 Chevy Silvarado
Old
1995 Rockwood Freedom 2280
2000 Chevy Blazer
States we have visited
