Jhureau881
SW Ohio
I don't understand the part that says "cycle the icemaker several times". I've shut off the water supply, blown water out of the line from the supply to the valve. Blown the water out of the valve to the icemaker. Dried the maker where the cubes are made. I don't understand how you can "cycle the ice maker several times".
Any ideas?
TIA.
Scott Hureau
....first time icemaker winterizer
Scott Hureau
97 HR Endeavor 37CDS CAT
sailor_lou
Connecticut
Good Sam RV Club
Scott,
If you removed all the water from the fresh water supply to the ice-maker's solenoid valve and the water from the solenoid to the freezer tray, you should be find. That's all I ever do. However, in order to to do this properly you need to remove both hoses/connections at the solenoid. I believe the bit about running a couple of cycles is for those that do not remove the hoses and you need the ice-maker to cycle in order to open the solenoid valve and let the water out/pink antifreeze in. I hope this makes sense?
Lou ...multi season icemake winterizer
05 Travel Supreme 38DS04
Mont G&J
Missoula, MT
Good Sam RV Club
Here's the way I cycle mine:
1. Lever "Down" in ice making mode.
2. Remove plastic cover on front of ice maker.
3. Rotate large gear in direction of arrow on gear. (I rotate mine clock-wise.) It's hard to turn, but only needs moved slightly before the ice maker will start it's cycle. Jack
PackerBacker
Home is Montreal Qc & Seasonal is NY Adirondacks
Jhureau881 wrote: I don't understand the part that says "cycle the icemaker several times". I've shut off the water supply, blown water out of the line from the supply to the valve. Blown the water out of the valve to the icemaker. Dried the maker where the cubes are made. I don't understand how you can "cycle the ice maker several times".
Any ideas?
TIA.
Scott Hureau
You did what I do. I drain the line, the solenoid and dry the well in the ice maker itself and it's been fine. Actually you don't even need to remove water from the ice maker itself since, by function, it's supposed to freeze.
Eric
2009 Holiday Rambler Admiral 33SFS (34' 3")
2008 Jeep Liberty - North Edition
FQCC/Camping Quebec, KOA, Good Sam, Coach-Net
My Photos
SunflyerA
Andover, Minnesota USA
Good Sam RV Club
PackerBacker wrote: Jhureau881 wrote: I don't understand the part that says "cycle the icemaker several times". I've shut off the water supply, blown water out of the line from the supply to the valve. Blown the water out of the valve to the icemaker. Dried the maker where the cubes are made. I don't understand how you can "cycle the ice maker several times".
Any ideas?
TIA.
Scott Hureau
Exactly...unscrew your ice maker line; it will drain and your done. Run pink stuff up to the shut off valve.
sunflyer
2005 Fleetwood Excursion 39S
350 Cat
If you are what you eat; then I am fast, cheap and easy
jerseyjim
New Jersey
Good Sam RV Club
There is a way...crude and rude to make the icemaker cycle quite quickly...my RV dealer mechanic showed me how (I forget), because I found the ice maker too problematic for winterization....and the wife complained it took too much room from the freezer.
So... after shutting off the water valve and disconnecting the electrics, I took it out and we make ice the old fashioned way...using a couple of ice trays. Company? Spring for a couple bucks and buy a bag of ice and dump that into a small cooler.
Works for me..............
twocruisin
Crystal River, Florida
I can see getting the water out of the line that runs up the back of the fridge because it might freeze because of the vent behind the fridge letting cold air in........The ice maker inside the freezer "Lives" in temps of 0 or below, it doesn't need "Winterizing", since it thinks it's winter all the time....
John
John
Crystal River
40 Foot Damon Diesel Bus
69RoadRunner
VA
Or you could turn on the refrigerator, leave the water pump and ice maker on, put the siphon hose in a gallon of RV antifreeze and wait for the line after the solenoid to get pink.
Just another option, and one that I did this past weekend.
In the Spring, I'll drain the icemaker lines and then run several cycles (until the container fills with ice) with fresh water.
Discard the ice, replace the bypass pipe with a new water filter and I'm done.
09 Newmar Ventana 3942
Bunkbeds for the munchkins
Jerry B
Ozark Highlands
Just unscrew the line from the solenoid valve to the ice maker. Let it drain. Be sure to reconnect the line after draining so you won't flood it in the future. Simple.
Jerry B
1996 Dolphin 535,F-53.
alfa38user
Fl
I think the point of cycling the icemaker is simply to make sure that all the ice is out. I do that by simply shutting off the water supply the day before, draining the plastic line at the solenoid, and letting the machine perform its normal cycle which expels the last of the ice into the bucket. After turning off the freezer, I then dry the icemaker , and drain the water from the supply line and water filter. (My trailer has a third fresh water drain for this line.) This proceedure will avoid any formation of mould etc.in the icemaker.
I would NEVER introduce RV antifreeze into the icemaker system as it would be more difficult (IMO) to remove all traces in the ice before using it next time, and is unlike being able to flow water continuously through the other piping and tanks where you might use the antifreeze.
Alfa38User
Montréal, Canada
Alfa Gold 38 (253 RLTES - 2000)
(SW Florida)
