RV.Net Open Roads Forum: Travel Trailers: towing with a f150
 > towing with a f150
Page of 7
Travel Trailers Related Tips
librty02
Western Pa
Posted: 10/18/09 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
Curious how many people tow a 30' trailer with a F150. Mine is a 08 fx4 supercab with the 5.4L and 3.73 rear end. I am looking to purchase a new keystone outback or passport in the upcoming spring both would have about the same max dry weight of 6500 lbs. The tow rating of the truck is 8900lbs with the 80% rule on that being 7120 lbs. Im just wondering how well my truck will pull this size trailer your imput will be greatly appreciated thanks
03 Jeep Grand Cherokee V8 TV
08 Ford F150 SC FX4 TV
07 Fleetwood Sun Valley
en3chix
middle peninsula, Virginia
Posted: 10/18/09 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
I towed a Surveyor SV291 with a '90 F150 that had 150,000 + on it. The truck was ragged out but towed the camper ok. I din't try and tackle an mountains. I always took it easy and let the truck do the work and not force it. I think you will be fine. The weight police on hear probably tell you different. Just take it easy, make sure your hitch and brake controller are set up right and enjoy your self.
DW '73, DD '99, DD '03
'09 Jayco Eagle 314 BHDS
'06 Chevy 2500 D-max 4x4
downtheroad
Puget Sound
Posted: 10/18/09 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
IF you want to follow the mythical 80% rule you will not make it. The 6500 dry weight with options, gear, liquids, etc. will be much more than your target 7120...Remember, no one camps in a dry weight trailer.
Keep in mind, regardless what is posted here on the net, the numbers and specs for the truck and trailer are the true determiner. How much under those numbers you want to be or how much over weight you are comfortable with is up to you.
"If we couldn't laugh we would all go insane"
GMC Duramax/Allison (LBZ)
Komfort 277TS Our Rig Picture
Reese Dual Cam HP
Lots of other stuff nobody cares about
murphy38
Hebron, MD.
Posted: 10/18/09 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
We pulled our 33' trailer with a f150 and it did ok on flat ground but after a trip to Skyline Drive Va. I found it was time for a new truck. Did not do well in the mountains at all. If you are just going to be on flat ground give it a try and see how you feel about, who knows might be ok for where you are towing.
2002 Chevy 3500 Dually, 8.1, Allison,
1995 33" Prowler
Loaded and Ready to go.
Our Camping and Photo Page
Our Web Albums
Campinfan
Washtenaw County, Michigan
Posted: 10/18/09 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
The 80 % rule was made up to account for the other 20% going into gear, gas, occupants etc in the truck. I had a 30 footer with my 06 F 150 and never had any trouble.
________
2008 F 250 FX4 4WD, V10, 4.10 Tow Command
35' 2007 Crossroads Cruiser CT32SB
Wonderful Wife and 3 small kids
familyman_2
Norfolk/VA/USA
Good Sam RV Club
Posted: 10/18/09 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
I have a f150 (5.4L w/ 3.55 diff)and trailer that totals just under 28' and 6400 lbs gross. With 2 adults, 2 kids and all the goods I wouldn't want anything bigger or heavier.
My truck is the older engine with 2 valves and alittle less power also doesn't help that I have the 3.55 diff.
Hope this helps.
Al
Me '69
DW '70
DD '96
DS '99
2008 Rockwood Roo 25RS
2001 23rbs Travelstar (sold)
2000 Suburban 1500 4x4, 3.73 rear diff., Prodigy, Equalizer Hitch
2003 F-150 5.4L, 2WD, 3.55LS rear diff.
Trying hard to camp to much...Hasn't happened yet!
carlstone05
Bellevue, NE
Posted: 10/18/09 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
My uncle used to tow a 34' tt with an F-150. I thought the truck was too small, but he said it did just fine. He towed from MN to TX and everywhere in between without an issue. I don't know the weight, but I would guess at least 6500#.
Good Luck and Happy Camping!
Carlstone
2005 Suburban 1500 2WD, 5.3L, 4.10
Prodigy Brake Control
Equal-i-zer Sway/Weight Distribution
2008 Cherokee Grey Wolf 26BH, Patriot Edition II
LAdams
Northern Illinois
Good Sam RV Club
Well, looking at the BASE figures I would say you'll be close to maximums and the overall TT lengths are a few feet longer than you actually state... Also bare in mind that delivered weight (UVW) is apt to be heavier than brochure weights...
The tow rating of the truck, while somewhat important as a guideline, is overshadowed by the truck's GVWR and GCWR numbers... Some would argue on these forums that these numbers are merely guidelines for warranty purposes, but I feel they are meaningful numbers which dictate the trucks overall performance and longivity...
The current trend on this forum, Towing, and Tow Vehicle forum subscribes to the theory that GVWR and GCWR are just manufacturers ratings for warranty and vehicle performance and can be exceeded without issue... I do not subscribe to that theory and use GVWR/GCWR as my maximum ratings for my tow vehicle...
That said, remember that all the opinions you receive here are just that - opinions, and as such, are worth about as much as you are going to pay for them...
Personally, I think your going to be close to maximums or possibly exceeding them, depending on how heavy you load your truck and trailer and how your truck and trailer are optioned out... The best thing to do is to weigh the combination and drive the combination and see how it feels you...
IMHO, a bit too much trailer for the truck, but other opinions will vary (I'm sure!!)
Oh and BTW - I used to own an F-150 and I loved the truck... Much more comfortable, better looking and nicer ride than my current F-250, but my F-250 is a towing beast - - - which my F-150 was not ...
Les
Passports
300BH 3050BH
Shipping Weight 5484 & 5725
Carrying Capacity 2051 & 1475
Hitch 535 & 590
Length 33' 6 & 32' 8"
Outbacks
300BH 301BQ
Shipping Weight 6729 & 7050
Carrying Capacity 1471 & 1150
Hitch 685 & 700
Length 32' 8 & 33' 6
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
2006 Nomad 3150 Double Slide (Bunkhouse)
Hensley Arrow
Jordan Ultima 2020
HUNTER THERMOSTAT INSTALL
HOME MADE WHEEL CHOCKS
librty02
Western Pa
Posted: 10/18/09 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
ok I think I found the perfect floorplan for me and my family its the keystone passport 2590BH. Listed at 4930 shipped 550 hitch weight and 28'10".
smkettner
Good Sam RV Club
Posted: 10/18/09 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
I pull 26' and probably 7300# with an old 260hp 5.4 and right at the rating, no worries.
Page of 7
