Gray Fox
Swansea Ma. USA
Good Sam RV Club
Hi Thanks for all the info about the Vornado heater that's what we will try.
Another Question Is it safe to leave the heater run all night while you are sleeping. My wife don't thing we should do that, what does everyone think? Thanks.....
Gray Fox
2005 F350 4x4 Diesel Lariat
2003 HHII LS RLBG
Always keep moving so you don't seize up.
ddreisbach
Kemah, TX
Good Sam RV Club
Do it all the time. Just make sure it's clear of anything flammable.
What is her concern?
mwallace61
Alabama
Good Sam RV Club
We do it. Just make sure it's in a clear area.
Mike & Karen
ForrestGump the Wonder Dog
pianotuna
Regina, SK, Canada
Good Sam RV Club
Hi Gray Fox,
If fire is a concern go for an oil filled unit. The surface temperature is much cooler, so there is much less risk of fire.
I run mine 24/7 during cold weather.
Gray Fox wrote: Hi Thanks for all the info about the Vornado heater that's what we will try.
Regards, Don
Kustom Koach Class C 28'5" 256 watts solar, 875 amp hours in two battery banks 12 volt batteries 2500 watt inverter.
downtheroad
Puget Sound
More than likely the heater will have "over heat" shut off protection and tip over shut off protection.
We do run ours at night from time to time, but put it up on a counter so that the dog can't tip it over if she decides to wander around.
"If we couldn't laugh we would all go insane"
GMC Duramax/Allison (LBZ)
Komfort 277TS Our Rig Picture
Reese Dual Cam HP
Lots of other stuff nobody cares about
bradyk
Calgary, Alberta
One of the features we like besides heating the trailer well is that the outside does not get hot to the touch. The only hot area is directly in front where the heat comes out. The rest of the unit gets just warm at best.
2001 Chevrolet 2500hd Silverado LT 4x4 6.0L/4.10
2005 KZ Outdoorsmen 2605PF
Champion 4000W Generator
Ken & Sandra
Shadow Cat,Yugi Dog, Jet Dog
16 Foot Renken Fishing boat
ata3001
Niagara Falls, NY
We use ours most of the time when heat is needed. Ours is a thermostatically controlled Pelonis heater. MUCH quieter than the furnace.
Ron & BJ
2008 Dutchmen Freedom Spirit FS180 (24 FT) w/full factory dark tinted glass & front window
2007 Dodge Ram 4 WD, Quad Cab, Big Horn Edition, 5.7L Hemi w/tow pkg, 3.92, Prodigy
Sandia Man
Rio Rancho, NM
We do run ours through the night but we are careful to place it where it can't be knocked over by pets or near flammable materials. Happy Camping!!
