luvcampingguy
Stillwater Minnesota
Good Sam RV Club
Does anyone know where the water filter is? Also I dont seem to have a gauge reading for my LP tanks at my command center that shows my tank readings and battery charge.
arizonadesertbrat
Where ever the pipeline leads
In the 2008 the water filter was in the cabinet under the sink.
ol Bombero-JC
" . . .gauge reading for my LP tanks at my command center . . .?
Never heard of that one - maybe a new innovation?
M GO BLUE
Southgate, MI
Never had heard about any on-board command center ever being able to read what is left in the LP tanks...that battery charge yes...LP tank no
ERIC & BEV
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fith wheel
Onan 5500W Marquis Gold gas generator
KEEP A LOOK OUT FOR OUR SPRING 2010 RALLY!
loydt
Concord, NC, USA
Good Sam RV Club
The water filter is under the sink. They leave it loose for you to install if you want it. There is no gauge for the LP. If you want one you will have to install it. The battery gauge is on the same panel as your fresh water, grey, and black tanks.
2007 Dodge 3500 Quad Cab DRW, 5.9 Cummins, 6 speed, 4x4, Jake Brake
2008 Jayco Designer 35 RLTS
2008 Discovery 40X DP
My Pictures
MrRepair
North East
The filter is under the sink and i don't have a propane gage in mine
yogi154
peotone il
Good Sam RV Club
Water Filter as said under sink. I am think of an external filter. I Have a 2010 and there's NO propane gauge on mine. Hope this helps
Wayne
