RV.Net Open Roads Forum: Class A Motorhomes: bugs in toilet???
 > bugs in toilet???
kphil24
indiana
Good Sam RV Club
Posted: 10/22/09 04:44am Link  |  Quote  |  Print  |  Notify Moderator
Two weeks ago, when I went to check on my rig, i noticed several bugs flying and crawling along the inside rim of my toilet. I sprayed, and killed them, wiped them out. Came back last night and several more again in the same area. Any ideas why?
travelwithwhippets
Posted: 10/22/09 04:59am Link  |  Quote  |  Print  |  Notify Moderator
Are they tiny little gnat-type bugs? We had the same thing happen this summer while camping at Prophetstown State Park in Indiana. When we moved locations, no more bugs. I never did figure out why we had them, so I'll be interested to see other responses.
2003 Mountain Aire Gas
New to us Jan. 2007!
2007 Toyota Matrix Toad
kphil24
indiana
Good Sam RV Club
Posted: 10/22/09 05:16am Link  |  Quote  |  Print  |  Notify Moderator
Yes, tiny little knat type critters.
Dennis Henderson
Crystal River, Florida
Posted: 10/22/09 05:36am Link  |  Quote  |  Print  |  Notify Moderator
Do a Google search on "sewer flies" and you will find out all about them.
Dennis and Cindy Henderson
fulltiming, currently at Crabtree Meadows at milepost 339 on the Blue Ridge Parkway in North Carolina
ddreisbach
Kemah, TX
Good Sam RV Club
Posted: 10/22/09 06:36am Link  |  Quote  |  Print  |  Notify Moderator
Also known as "drain flies".
KD4AO
Punta Gorda, Fl., USA
Posted: 10/22/09 07:02am Link  |  Quote  |  Print  |  Notify Moderator
I had the same thing a while back when we were in a grass covered storage yard. I finally solved the problem by removing the cap on the roof vent and placing a rather fine bug screen over the end of the vent pipe then replaced the cap over it. No more little bugs.
Bob
jjtx22
Baldwin, Florida
Posted: 10/22/09 07:18am Link  |  Quote  |  Print  |  Notify Moderator
Being from South Texas, we refer to them as piss flies. I changed my toilet and they disappeared. Before R&R of commode, I took my toilet apart and cleaned it. Re-installed only to have the piss flies come back. Apparently there are crevices where fecal material can accumulate inside the base of the toilet that will sustain piss flies.
2003 Challenger 34TLB
2007 Ford F350 4X4
sowego
northwest panhandle of Nebraska
Posted: 10/22/09 07:38am Link  |  Quote  |  Print  |  Notify Moderator
Yup, yucky problem. Our toilet was inop for a couple of weeks while we order and replaced the water valve, in that time we had skeeters lay eggs somewhere, we think inside the rim so guess what -- we had skeeter larve hatching and crawling around. All we could do was clean the toilet well with bleach water, spraying up into the rim. In a few days they either all hatched and got killed off or the bleach killed them.
2002 Tiffin Phaeton
2005 Malibu Max toad
J Walker
Oakton, Va
Posted: 10/22/09 08:22am Link  |  Quote  |  Print  |  Notify Moderator
Some toilets like older Thetford have an overflow that is supposed to have a one way valve but it doesn't work. That could allow critters from the black tank into your MH. I plugged my overflow mainly to keep odors out. Newer Thetford toilets don't have an overflow. BTW mine is a 2000 Aqua Magic. I believe that 2-3 years after mine the overflow disappeared.
Jim Walker
2000 34' Damon Ultrasport DP
2009 Malibu
Brake Buddy
kphil24
indiana
Good Sam RV Club
Posted: 10/22/09 08:46am Link  |  Quote  |  Print  |  Notify Moderator
Kinda makes me think twice before sittin down on the thrown
 > bugs in toilet???
