RV.Net Open Roads Forum: Class A Motorhomes: Double Pane Windows
 > Double Pane Windows
Burp
St. George's Island, MD
Good Sam RV Club
Posted: 10/22/09 11:15am Link  |  Quote  |  Print  |  Notify Moderator
I used to work in the glass industry. Our shop made insulated units. That was about 18 years ago. Here is a few things I learned.
  • The metal spacer between the two panes contains a chemical that absorbs moisture. It is not just a spacer.
  • Our shop could take just about any shape and make it into an insulated window. All we needed was a template and that could be cardboard.
  • Most of our windows did not use inert gases. Expensive.
  • Using tempered or non-tempered glass did not make much difference. It just added one step to the process, tempering.
  • All tempered glass must have a "bug". An etched mark in a corner to indicate it is tempered.
  • Glass shops do not do the work most of the time, it is done at a processor (like us). The glass shop would add about 70% or more to the price after we delivered it to them.
That was some time ago so if anything, the processes have improved. Back then it only took us about 2 or 3 days to make any insulated unit.
2007 Winnebago Voyage 33V (Workhorse, W20)
2008 Saturn Aura, Falcon 2, BrakeMaster
Me, the Wife , Edgar, Gus , and Sarah
Places we have camped in an RV
CJ5 jeeper
Auburn, Ca
Good Sam RV Club
Posted: 10/22/09 11:56am Link  |  Quote  |  Print  |  Notify Moderator
I think you will find most good glass shops can repair them. Check with your local shops. With the economy they will be happy for the business.
Jim@HiTek
Gresham, OR, USA
Posted: 10/22/09 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
sum1 wrote:
Hi, Jim. Actually, all the windows are required to be tempered and the windshield must be laminated. A popular option in residential windows is argon gas, but like you said, I think it's rare or non-existent in RVs.
Burp wrote:
I used to work in the glass industry. Snip.
I've gone around and checked and I DO have the bug on my windows. It's on each pane, upper corner. Not always easy to see.
I stand corrected.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Fleetwood Bounder, '94
Cummins Diesel, 190HP, 36.5'
Black Rock Lava Park, Nevada
Londo13
Hammond
Posted: 10/22/09 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
Actually the hardest part is removing and re-installing the unit. Once out, "Very Carefully", if you nick the glass, its history, drill 2-3/16 holes in the side frame towards the inside from opposite sides. Put a small piece of 3/16 brake tube in one hole hooked up with a hose and use the argon/co2 mix from a mig welder. Let it slowly 'leak' into one hole and exit the other. The key is the dry gas. It may take 2 hours or more but when you are sure all traces of moisture are gone, use black silicone in the holes to plug them and coat the perimeter with sealer to prevent moisture incursion.
Bruce & Tam
1 Fur Kid (Labradorable) Troyer
Going Full Time in the Near Future
"Never argue with Idiots. They will just drag you down to their level and beat you with experience."
SunflyerA
Andover, Minnesota USA
Good Sam RV Club
Posted: 10/23/09 08:32am Link  |  Quote  |  Print  |  Notify Moderator
I'm going to be taking some of mine apart to clean and reseal....I haven't done it yet, but I have been inspecting and considering how to do this; I have not seen any metal inserts between the glass. The seal looks like black vinyl. Are you talking about residential windows? Maybe the RV windows are just way cheaper or is there something special about that vinyl seal?
sunflyer
2005 Fleetwood Excursion 39S
350 Cat
If you are what you eat; then I am fast, cheap and easy
Burp
Good Sam RV Club
Posted: 10/23/09 08:52am Link  |  Quote  |  Print  |  Notify Moderator
There is a type of spacer that looks like a black vinyl. If I remember right it was used for odd shapes and contains the desiccant (the stuff that absorbs the moisture) right in the vinyl.
Jim@HiTek
Gresham, OR, USA
Posted: 10/23/09 10:26am Link  |  Quote  |  Print  |  Notify Moderator
Not sure if they all are, but many of these windows use butyl rubber to form the seal.
tropical36
Southwest Florida_USA
Posted: 10/23/09 10:43am Link  |  Quote  |  Print  |  Notify Moderator
I've been reading these problematic window threads for some time now and since I have nothing more to offer for the OP's question from a tech standpoint, I can only say that I'm glad to have single panes and that would be a strong consideration for me if I had to replace any doubles.
"We are often so caught up in our destination that we forget to appreciate the journey."
1998 36ft. National Tropi-Cal Model 6350, with a tag axle and one slide, on a 1997 P32 Chevy chassis....7.4 Vortec Engine
theRoadrunner
Lakeland, FL
Good Sam RV Club
Posted: 10/23/09 11:12am Link  |  Quote  |  Print  |  Notify Moderator
I have a problem with one window in my old Winnebago. I think after reading this forum I will repair it myself!
Thanks for posting!
Jim & Brenda
"just runnin' down the road"
On R & R
Retired and Riding
On our Honda Gold Wing when we get where we are going
FIRE UP
Ramona, CA. USA
Good Sam RV Club
Posted: 10/23/09 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
tropical36
I did just exactly what you stated. I had trouble with my dual pane windows in both the drivers and passengers slider and stationary windows, all four of them were leaking and had developed calcium deposits on the inside. I won't take up the OP post here but what I did was had both the front sliders and stationery's changed to laminated glass and they work flawless and have had "0" problems since the conversion. Just my two cents here. Good luck.
Scott
Scott and Karla
San Diego Fire Department RETIRED
1999 Bounder 34V w/slide, V-10 W/BANKS
toad-'04 Yellow Jeep Rubicon
2002 Stream Silver Metalic GL 1800 Goldwing
KI60ND
