hammerdown
Park City, Ut
Good Sam RV Club
To get the water left in the lines after pumping in the pink stuff between the bypass valves and the water heater should I crack the upper and lower bypass valves and let a small amount of pink stuff go into the water heater?
goff1256
co
Good Sam RV Club
Yes, leave the dran plug out of the WH.
Erick & Jackie Goff; Plus Sophie the Fu Fu Dog
CloudDriver
New Jersey Shore
Good Sam RV Club
Yes, but just a little. Antifreeze is not needed in the WH as long as it has been drained. I always put the drain plug back in to keep the critters out.
2003 Winnebago Minnie 24F - Ford E-450
skipnchar
Topeka Kansas USA
We've never bothered and haven't had a problem. It MAY depend on just how your bypass system is designed. Ours has only an inch or two of lines beyond the valve until it reaches the tank but some have the valve located some distance from the tank.
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
mecreature
Indianapolis, IN
I had to open it up for a bit to get the pink in that part of the lines
then I open the low point till some pink comes out of there too. .
98 Skyline Nomad 1950 Compact
2004 Silverado 1500 EXT. 5.3 3.42 Axle 2wd
another_newfie
Ontario
It really depends on your bypass design. Mine is a 1 valve so no need in my case. I just drain it, bypass it, then pop the anode back in place. For a 2 or three valve you might indeed have some water in the lines. I would do as you suggest, a little pink in the WH will do no damage.
2009 Springdale Summerland 2600 TBL
2008 Ford F-150 Supercrew XLT 4X4
Prodigy + Equal-i-zer
4 Seasons Camping Tips & Tricks!
John H
Kansas City Mo.
Hammerdown, the way I understand it is the drain in the water heater is the absolutely low point drain of the water heater & its system. By that just like the low point drain of your trailer, it/they are designed to be the lowest point thus allowing by gravity to drain water completely. The inlet and outlet of the water in the heater is higher in the tanks design, thus when the by pass valve is opened and the supply & outlet is closed any water remaining, line or tank would drain by pulling that plug located at the very bottom of that tank. As far with the rest of the trailer system, the low point may not be the low point of the trailers water lines. There could be a sagging line some where, and most likely is. Capturing some water, thus the use of a pump to pump anti-freeze threw out the whole system occupying all of the lines space.Including by the way the pump itself, with the pink stuff. Remember to be sure to open/pump ALL WATER LINES in your model. Water intake (before pump), outside shower, tub, sink/s, toilet/s, any where there was a hint of water while in use. The p-traps in the sink, and tubs are an example of trapped water, by literally their design. Thus why you have to pour anti- freeze down every drain. Both, or more than two, holding tanks, the manufactures are usually very stringent in their design to have a good drain, in these. Still I pore a small amount of anti--freeze into each of these as a precaution, including that excess that goes threw the p-traps. Even though latter in the showers/sinks come spring, the smell & pink stuff seams to linger for some time
John H
Polishnurse
Schodack, NY
I put the plug back in the heater but only enough to hold it. I don't like mice in my Hot water Heater, I find they can be more of taste problem and smell problem than the pink stuff. They are almost imposable to get out once they there cooked. Bill
John H
Kansas City Mo.
Polishnurse, To a lurt my self. How do you surmise the mice got into the heater with that exterior door closed & secured ? I have never, in all my years, though of this, and maybe I should have.
Polishnurse
Schodack, NY
John H wrote: Polishnurse, To a lurt my self. How do you surmise the mice got into the heater with that exterior door closed & secured ? I have never, in all my years, though of this, and maybe I should have.
Same way the get into hope chest, dressers and the best one I remember a ketchup bottle half filled with ketchup. They do it when your not looking, they way it's kept a mouse secret. Bill
