RV.Net Open Roads Forum: Beginning RVing: Small Solar Panel
 > Small Solar Panel
Beginning RVing Related Tips
Fireslayer
West Coast
Posted: 10/23/09 08:26am Link  |  Quote  |  Print  |  Notify Moderator
I have a small solar panel that is about 6X18, and it plugs into a cig. lighter.
If I leave it in my window for numerous days, will it draw the current from the battery at night? It really doesn't put out much juice, but something is better than nothing, so I'll use it if it won't cause damage.
Thanks
Dave
eaw46
Regina Sask. Canada
Posted: 10/23/09 08:51am Link  |  Quote  |  Print  |  Notify Moderator
If its in the sun all day the then it will put more charge in during the day that the small LED light will draw out at night. Make sure snow does not cover the windshild and block the sun from getting to the panel or it will not work. Eddy
Eddy from the Great White North
1997 Triple E Commander 35
bldrbuck
Boulder, Colorado
Good Sam RV Club
Posted: 10/23/09 09:08am Link  |  Quote  |  Print  |  Notify Moderator
Electricity from the Sun by phred
If this does not help try a search. In general small solar panels are not very effective. They must be in direct sun and then may maintain a battery. You might add the wattage of your panel to your post. I would suspect 15 to 20 watts.
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
trucker_101
Regina SK Area
Posted: 10/23/09 11:59am Link  |  Quote  |  Print  |  Notify Moderator
Thanks
Dave
I have the same solar charger. I've used it for at least two years now "full time" it works great,I've never had a dead or low battery of either the starting battery or the other batteries.Where I live it regularly gets down to -30 in the winters, this way I've never had a frozen dead battery.
1973 32ft Airstream
1985 28ft Ford Class C Royal Classic
1986 38ft Enroute 5th Wheel
tvman44
Southwest Louisiana
Posted: 10/23/09 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
Could put a diode in series to prevent that but it would lower the charge rate a little.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
Fireslayer
West Coast
Posted: 10/23/09 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
I have the same solar charger. I've used it for at least two years now "full time" it works great,I've never had a dead or low battery of either the starting battery or the other batteries.Where I live it regularly gets down to -30 in the winters, this way I've never had a frozen dead battery.[/color]
Is this something that I can plug in and leave for a month at a time?
Dave
hwybnb
Posted: 10/23/09 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
I too have a similar panel with the Coleman name on it, rated at 15 watts. It works great for me but mine does not have an LED. I believe the panel has a diode at the output to prevent back current - most of them do. Have you checked to see if the LED remains on in the dark?
Chuck&Gail
In the Colorado Mountains
Posted: 10/23/09 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
I use solar to keep four different batteries charged. All work well. Three are 5 watt, and HTTTH is a 15 watt. All mine have a diode built in to prevent battery discharge at night.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
trucker_101
Regina SK Area
Posted: 10/23/09 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
Dave
I should add that the one I use is a "trickle charger" If yours is any larger than a trickle charger then you should use a "Charge controller" to keep your batteries from being over charged.
murffdog
Poughkeepsie, NY
Posted: 10/24/09 06:47am Link  |  Quote  |  Print  |  Notify Moderator
I removed the LED light by changing the plug, works great.
 > Small Solar Panel
