RV.Net Open Roads Forum: Travel Trailers: Where to pad when installing covers.
 > Where to pad when installing covers.
Travel Trailers Related Tips
tomdrobin
Perry, MI
Posted: 10/24/09 09:00am Link  |  Quote  |  Print  |  Notify Moderator
I would like to hear some tips from those of you who use covers. Things like what are the wear spots where you protect against abrasion, before I install it.
I already have the cover. A Goldline made by Carver Industries that I bought for my 2000 Jayco 292 Quest. It came with some self adhesive material to put at wear points. It appears to be well made. Looks like the same type material used for the cover on my Waverrunner.
dalenoel
Howell, Michigan
Good Sam RV Club
Posted: 10/24/09 09:03am Link  |  Quote  |  Print  |  Notify Moderator
Problem areas I had were the edges of the ladder. I covered each step end with the swim noodles.
04 Dodge RAM Quad Crew Cab 4x4
08 Jayco Eagle 322 FKS, Hensley Arrow, Prodigy Controller
Wife and I, Oreo the Malshi, and maybe a grandkid or two
trails2004
Wyoming
Posted: 10/24/09 09:10am Link  |  Quote  |  Print  |  Notify Moderator
Around the corners of your awning, bumper and jacks if you have them or anything that protrudes on the outside of the campers skin.
2002 Dodge Ram 2500 SLT 4x4-2004 Hallmark Cuchara XL 9.5 w/Carbon Fiber Roof,1997 Grumman GV19TC,1997 Haulmark 27ft V nose round top - toy trailer
FXSTOHIO
Ohio
Good Sam RV Club
Posted: 10/24/09 09:13am Link  |  Quote  |  Print  |  Notify Moderator
The corners are the only place i pad - the rain gutters will ripp the cover in the first heavy wind if you don't pad them.
2008 Pilgrim Lite 21LRB
2004 Chevy Silverado Extended Cab 4x4 5.3 Tow Pkg 3.73
Yamaha EF2400IS
Polishnurse
Schodack, NY
Posted: 10/24/09 09:16am Link  |  Quote  |  Print  |  Notify Moderator
I used the pool noodles on my Antenna (radio) stump after removing the antenna, the ladder rails, wind shield wiper arms (noodle). Some areas were to protect the cover as much as protect the finish. Bill
Padlin
W. Ma.
Posted: 10/24/09 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
On my manual Awning, the lever you throw to open or close it pokes hole every time.
Bob & Deb
W Ma.
04 GMC 1500 4X4, 5.3L
06 Starcraft 18SB
mockybird
Mocksville,NC
Good Sam RV Club
Posted: 10/24/09 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
Remove the drip spouts that you add to gutters to stop black streaks.
Gary
mayberryman
mount airy,nc
Posted: 10/24/09 10:14pm Link  |  Quote  |  Print  |  Notify Moderator
Bubble wrap works well. I remove the gutter extensions at each corner first, then use bubble wrap at all corners and all the other places that have been mentioned.You can buy it in rolls at Staples stores.Works well for me.Hope this helps.
daystrom
NE Ohio
Good Sam RV Club
Posted: 10/24/09 10:19pm Link  |  Quote  |  Print  |  Notify Moderator
What do you use to attach the bubble wrap?
2010 AmeriLite 25BH
2005 Dodge Ram 1500 QC 4x4 3.92 Axle
2004 Viking Epic 17.5LS (SOLD 2005)
2005 Jayco Select 12HW (SOLD 2009)
Lots of camping photos
mayberryman
mount airy,nc
Posted: 10/24/09 10:32pm Link  |  Quote  |  Print  |  Notify Moderator
I usually just stand on a stepladder and tuck it under at each corner once the cover is in place. You can use some clear duck tape at other places.
