RV.Net Open Roads Forum: How Do You Adapt 1" Hose to Sewer Dump Receptacle?
 > How Do You Adapt 1" Hose to Sewer Dump Receptacle?
Tech Issues Related Tips
Lakejumper
Northern California
Good Sam RV Club
Posted: 10/24/09 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
I just bought a Flojet macerator and am planning on getting a 1" hose. What is the best way to connect it to a 3 or 4 inch sewer dump opening to seal off the odors? Have any of you made an adapter that works using PVC pipe or have any other ideas?
Lakejumper
2007 Cardinal 30WBLE, 5th Airborne pinbox
2004 Chevy Silverado 2500HD CC SB 4X4, D/A, Bilsteins
PapPappy
Wilmington, NC
Good Sam RV Club
Posted: 10/24/09 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
You should have a cap that fits right on your dump connection, with a garden hose fitting. If you don't, you should be able to buy one at any RV store or dealer.
I don't know why you want the 1" hose.......a 3/4" garden hose should be fine, and a lot easier to buy.
The Flojet should have a connection on it that will connect to a garden hose....and the Flojet connects directly on to the tank's dump connection.
You may be overthinking this
Happy Camping!
Bill & Claudia / DD Jenn / DS Chris
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie & Beau
RIP: Cookie (Sheltie) & Gidget (Lab-mix) over the Rainbow Bridge.
Purchased April 2008 FMCA# F407293
The Pets
robatthelake
Vancouver Island
Posted: 10/24/09 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
Also unless You intend to leave the Hose connected permanently the transfer process is very quick so Odor shouldn't be a problem!
Rob & Jean
Dutch Star Diesel Pusher ..Tracker 4X2
BENT ARROW
CO.
Posted: 10/24/09 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
You can buy the parts at Home Depot, mine took 3 PVC, 3 cast iron and a hose connection.
Pap- I think he means to the dump site not at the MH end.
Bent Arrow
99 PACE ARROW 35'
Chevy 4x4
4 Wheel Pop-Up
S10 Blazer ZR-2
hershey
Albuquerque,(fulltime) NM, USA
Posted: 10/24/09 08:30pm Link  |  Quote  |  Print  |  Notify Moderator
Home Depot/Lowes will have all the fitting you will need. Just cruise thru the plumbing isle with the end of your hose and start matching up the various fittings. You can then find adapters to fit the various sewer dump holes.
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99 - 5
Gunship Guy
Posted: 10/24/09 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
Walmart sells a garden hose adaptor that attaches to a standard sewer hose. Just saw it in the rv section today.
PICS OF STUFF
I like chicks with nice tents.
Lakejumper
Northern California
Good Sam RV Club
Posted: 10/24/09 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, I'm looking for the fitting to the dump station end. I already have everything to connect to the RV. I like the idea of using a 3/4" hose as it takes up less space. I've seen 3 and 4 inch sewer caps but nothing that screws into the opening that can adapt to a hose fitting. I'll check out the plumbing departments. I just thought that maybe someone had already done this.
CloudDriver
New Jersey Shore
Good Sam RV Club
Posted: 10/24/09 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
We use a Sewer Solution to dump the waste tanks. It came with this sewer adapter to connect to either a 3 inch or 4 inch campground waste fitting. I'm pretty sure the Sewer Solution waste hose is 3/4 inch so this part might work for you. Or you could cobble up something similar from parts at Home Depot.
Did you try getting the needed parts from Flojet?
2003 Winnebago Minnie 24F - Ford E-450
SCVJeff
Santa Clarita, CA.
Posted: 10/24/09 11:25pm Link  |  Quote  |  Print  |  Notify Moderator
You can find almost anything you need HERE
Jeff - WA6EQU
Gunship Guy
Posted: 10/25/09 08:04am Link  |  Quote  |  Print  |  Notify Moderator
The adaptor at Walmart would work. Most people use one of those 90 degree connectors where one end is on your sewer hose and the other end fits down into the sewer opening. Just attach the Walmart adaptor to the end normally occupied by the sewer hose. Sure is a lot easier than finding pieces and parts at Lowes and rigging something together.
