RV.Net Open Roads Forum: Tech Issues: Battery Question
 > Battery Question
Tech Issues Related Tips
Old & Slow
Posted: 10/26/09 07:23am Link  |  Quote  |  Print  |  Notify Moderator
garry1p wrote:
I added distilled water to a spilled battery and that was the wrong thing to do.
bill h above has the correct answer.
I ended up having to replace what was a perfectly good battery after diluting the electrolyte.
Someone might tell us 'is it okay to empty the batteries and start all over with new electrolyte?' Would this be a possible solution? A chem to refresh the plates? Lot's to be learned about batteries.
jauguston
Bellingham, WA
Posted: 10/27/09 10:58am Link  |  Quote  |  Print  |  Notify Moderator
Ideally the fluid you put back into a cell should be the same specific gravity as the fluid in the cell. If the battery was fully charged when the fluid was lost new acid could be added. If the battery was dead the lost fluid would have been water. Anywhere in between to do it right you would need to match the SG to what is in the cell.
Jim
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 275
AIMS 2500w inverter 4-6v GC batteries
4-Kyocera 130w solar panels SB3024iL MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
 > Battery Question
