RV.Net Open Roads Forum: Class A Motorhomes: Slide question…
 > Slide question…
AZPops
Wherever the Job takes us...
Posted: 10/26/09 10:04pm Link  |  Quote  |  Print  |  Notify Moderator
If I’m on shore power (inverter switch in the off position, inverter panel displaying DC Volts @ 13 and DC Amps @ 10, AC INPUT and INV/CHRG light is lighted), the batteries wouldn’t come into play when extending or retracting the slide would it???
The slide in the Eagle is mechanical, it uses an electric motor and gears to work the slide.
Thanks,
Pops
97' AC Eagle, singel kitchen slide (see profile)
* This post was edited 10/26/09 10:14pm by AZPops *
Captain: Pops
Ist Mate: Harlee "The Vicious Attack Dog", but only if you try to move her when she's sleeping...
Still the Trouble Maker: Calvin
The Texan
Summer: Cascade, Idaho - Winter: Warm weather
Posted: 10/26/09 10:13pm Link  |  Quote  |  Print  |  Notify Moderator
Don't know about your Eagle, but my slide motors are 12V and work off the battery and if not plugged in, I have to have the generator running to ensure proper voltage to the slide motors.
Bob & Betsy - USN Ret'd '78 & FL LEO Ret'd '03 & "Oath Keeper"
'05 HR Endeavor 40PRQ, 400 Cummins W/ 405w/35A solar system -Pulling an '05 GMC Sierra LT, CC, Z-71, w/ 2010 Silver Rzr riding in the toad.
Where the wheels are stopped
bldrbuck
one or the other
Posted: 10/26/09 10:18pm Link  |  Quote  |  Print  |  Notify Moderator
The slide more then likely is powered by the battery. Since you say it is gear driven that is almost a sure thing. It takes a lot of current to move slides. Being plugged in will help the battery but not a great deal.
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 35' King of the Road 5er, 192 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 2 Trogan T105 Batteries, Me, my wife and 2 maltize furkids.
wallynm
Los Alamos NM
Posted: 10/26/09 10:23pm Link  |  Quote  |  Print  |  Notify Moderator
Not unless the slide is wired direct to the battery bank. Turning the inverter creates 120 volt power. On our DSDP the slide motors are 12 volt and do not require the inverter to be on to work. I assume when we are on shore power the batter bank operates the slide motors, but have never checked. I know the inverter will charge the battery bank even when it is in the off position. Not sure how you get 12 volts to the slide motor when you are on shore power.
My slide in the Eagle is mechanical, it uses an electric motor and gears to work the slide.
Thanks,
Pops
DONATE THAT OLD CELL PHONE TO SUPPORT SOLDIERS click here
Have a Cat Engine Yahoo Group or Cat RV Club Web Page
Have a Freightliner Yahoo Group or FCOC Web Page
2002 DSDP 3567 PUSHED BY KITTY KAT
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
Jay58
Melbourne (central east coast) Florida
Posted: 10/26/09 10:28pm Link  |  Quote  |  Print  |  Notify Moderator
Slide works off of Batteries, inverter / converter usually has a battery charger inside. be sure batteries are full of distilled water, charged, cables clean and tight is the first things to do
1996 HR Endeavor 37.5
230 ISB, 6 spd. Allison
Central Florida (East Coast)
Jay58
Posted: 10/26/09 10:29pm Link  |  Quote  |  Print  |  Notify Moderator
Measure volts and amps at the slide motor to be accurate.
Yaj
The Milky Way Galaxy (Hartford, WI)
Posted: 10/26/09 10:40pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 96 HR with the one big kitchen slide, electro-mechanical. It operates off the batteries, I don't know if chassis or house. On ours the switch got bumped and stuck while driving and burnt out the windings in the motor. New motor $400. I had it rewound for about $100. Works good again. Luckly it happened with the slide in because I can't see how to move it manually. Thats one reason I didn't want to replace with same motor as I think a motor with a crank could be retrofited in its place. Anyway I had to take off the guards to get to the motor where I was able to check for 12V which I had, that pointed to a bad motor.
Hi Jay58, I'm looking for wiring diagrams for the TV cutout!
1996 HR Endeavor LE,Cummins 5.9 230hp, Allison 3060,
Front-Yamaha Enduro, Rear-Honda Helix Geeser Cruiser + 2 bikes,
22ft 1977 Cruiser in tow.
1 DW, 2 kids.
2 dogs, 2 cats.
I wasn't thinking this far ahead!
Deen
Vancouver, WA
Posted: 10/27/09 12:18am Link  |  Quote  |  Print  |  Notify Moderator
Our DSDP says to either be on shore power or run the gen. when moving the slides.
AZPops
Posted: 10/27/09 02:31am Link  |  Quote  |  Print  |  Notify Moderator
Batteries are a year old (x4 6 volts). I check the water level once per month when I exercise the genset.
About three weeks ago, I had to replace the pin in the slide’s gear (it sheered off). Since replacing the pin, when I retract the slide it pauses (actually stops) about half way.
When this happened, I’d extend the slide a few inches then retracted the slide. After repeating this procedure a few times, the slide will retracted fully into the rig.
I’ve been trying to figure out why it’s doing this.
Thanks for the responses,
Pops
brobox
Sunny SW. Florida
Posted: 10/27/09 06:08am Link  |  Quote  |  Print  |  Notify Moderator
Check to see that the pin has not come out a bit and binding up.
On my slide control board I have the thrust adjustment. Check to see if you can increase the thrust on yours. It only take a hair of a turn to increase the thrust.
Chuck
02 Travel Supreme, 2 street side slides
09 Toyota Tacoma 2WD
 > Slide question…
