RV.Net Open Roads Forum: Cooking and Baking with a Conventional Oven in a 23B
Open Roads Forum  >  Hybrid Travel Trailers
 > Cooking and Baking with a Conventional Oven in a 23B
Hybrid Travel Trailers Related Tips
LEMII
Jonesborough, TN
Posted: 10/27/09 08:17am Link  |  Quote  |  Print  |  Notify Moderator
Okay, I've read a few suggestions here and there about getting used to the oven in a camper. We have the usual gas oven in our '07 Jayco 23B. We've not yet used it. What are some pointers and tricks to using the oven? Let's say I want to bake a pizza or make a batch of cookies or brownies.
I'd like to collect the strategies and tactics that work well and the mistakes others have made so I can try to avoid them.
Thanks in adavance for your input.
Me
My lovely and gracious wife
Maggie, our Yellow Lab
2007 Jayco Jayfeather EXP 23B
2008 Toyota 4Runner V8 Limited AWD
wa8shc
Parma, Ohio
Posted: 10/27/09 08:28am Link  |  Quote  |  Print  |  Notify Moderator
Wife says to not set heat quite as high as called for, and keep a CONSTANT watch on what your cooking.
She claims ours will either under cook or over cook, but you wont know which unless you keeping good eye on item
Just her opinion
Denny WA8SHC and Rita WB8TIR
Siberian Husky Ta'kya (Princess RIP 10/04 Taz RIP 5/12/08)
2007 Dodge Ram 2500 Quad Cab 5.9L CTD 3.73/LSD,Quadzilla RECON monitor
2008 Rockwood 8243S 5th wheel
Pullrite 14K Superglide & MorRyde pinbox
Sandia Man
Rio Rancho, NM
Posted: 10/27/09 08:33am Link  |  Quote  |  Print  |  Notify Moderator
A pizza stone or tile helps to even out temps when using your oven.
20carfans
Chesapeake, VA
Posted: 10/27/09 08:38am Link  |  Quote  |  Print  |  Notify Moderator
We have a 2008 Jayco 19H. The center of the oven, where the burner is will get too hot and burn the bottom of cookies, biscuits, etc. One tip we have learned here is to use a stone or tiles to evenly heat the oven. We haven't tried it yet, but we did buy a perfect fitting stone at BB&B this weekend. It is an Oneida 15" x 14 3/4". We were worried we would have to stow it wrapped in a bath towel in a cabinet so it would not bounce allover the oven and break. Nope ... perfect snug fit, will not slide or bounce in the oven.
I'll post back when we actually use it.
arizonadesertbrat
Where ever the pipeline leads
Posted: 10/27/09 08:39am Link  |  Quote  |  Print  |  Notify Moderator
A little off topic, but I don't understand why they can put a man on the moon but can't put an oven in an RV that will work right
tundraman67
Brandon, FL
Posted: 10/27/09 08:41am Link  |  Quote  |  Print  |  Notify Moderator
I use mine all the time. I cut a pizza clay to fit on the rack and use it to cook pizzas, bread, and biscuits. I actually do pizzas every Friday night we are camping in it, the first ones were a little more done on top than the bottom until I put the clay in and now they are wonderful. It is really convenient when I need an extra oven at the house (Thanksgiving, Christmas, etc)...it's small but can handle the little stuff that takes up the most room in a real oven and costs less than the electric one in the house. Just remember to put something underneath the stuff to collect overflow. It takes a little time to adjust if you are used to cooking with an electric one because of the gas and the size. Happy cooking....
Tundraman67
2007 Tundra DC 5.7
2006 Jayco 232 HTT
DW, 1 Teenager (the second one finally in college), and a rescued greyhound
LEMII
Jonesborough, TN
Posted: 10/27/09 09:34am Link  |  Quote  |  Print  |  Notify Moderator
Should I expect a gas oven to heat up / cook faster than our electric confection oven at home?
PamfromVA
Fauquier County, VA
Posted: 10/27/09 09:42am Link  |  Quote  |  Print  |  Notify Moderator
Here is something that I discovered with my oven. Once the pilot light is lit, leave it for a couple of minutes, then turn the dial slowly to the desired temperature. When I turned the dial up fast, the temperature would sky rocket to up over 500 degrees no matter what I set it to on the dial. Also, keep a thermometer inside to monitor the temperature because it is rarely based on the dial.
2007 Coachmen Captiva 245DS
2007 Toyota Tundra double cab 5.7-liter V8
One DH
two DS's (one left at home still in school)
two very spoiled camping dogs
crckt7
Maine
Posted: 10/27/09 09:44am Link  |  Quote  |  Print  |  Notify Moderator
Does anyone have a microwave in there 23b? Is it a microwave and convection oven or just a microwave? I am getting a 2001 Jayco 23b next week and was wondering what it was.
Roy and Sandra Crockett
2001 Jayco Kiwi 23b
? Tow Vehicle
bikendan
Napa, Cal.
Good Sam RV Club
Posted: 10/27/09 09:48am Link  |  Quote  |  Print  |  Notify Moderator
regular microwave. only the more expensive RV's have the combo ovens. even the new hybrids only have basic microwaves.
Dan- Firefighter, Shawn- Musician/Entrepreneur, Zoe- Faithful Golden Retriever, 2007 Chevrolet Avalanche LS, 2007 Rockwood Roo 23SS w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
