RV.Net Open Roads Forum: Toy Haulers: Cracked Frame
Search only in Toy Haulers
 > Cracked Frame
Toy Haulers Related Tips
1Sanman
Bakersfield,CA
Posted: 10/27/09 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
Well, like the post says cracked frame. The frame is cracked above the axles in multiple places. I bought this trailer over a year and half ago September of 2007. I started this adventure in july of this year. I first contacted Heartland then, the dealer. Dealer started dealing with Lippert, they said out of warranty (Trailer was manufactured in 06) They have a two year warranty. Heartland flat out said, not there frame and they were not fixing it. Called the insurance and after all their steps, looks like normal wear and tear and they were not going to fix it. Normal wear and tear, get real this is a manufacture's defect. The problem is the hangs are too long and the frame is to WEAK and the gussets are way too short. When you have the bolts in the last hole and every time you turn your trailer that causes the frame to flex and crack. Also, there is another trailer in town that has a cracked frame that lipperted came out and looked at. The tech said that was the worst he has seen, as if he seen a lot of cracked frames. So, everyone needs to check there frames above their axles for cracks, since it looks like there is a problem going on here before someone gets hurt or god for bid gets killed from this.
bldrbuck
Boulder, Colorado
Good Sam RV Club
Posted: 10/27/09 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
Try Trailer Life's ACTION LINE.They seem to be able to convince manufacturers and dealers to fix problems.
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
ernestfortier
Palmdale, Calif.
Good Sam RV Club
Posted: 10/27/09 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
I had a 32'Tahoe TT and the frame cracked above the axels. I noticed the cracks when the TT was 3 years old. The dealer told me that it's my problem. I contacted Trailer Life's Action Line. They made some contacts and Tahoe called me and told me who made the frame and where they were located. I called the frame manufacturer and they set up a appointment for me to take the TT in and they would repair it while I waited. I left the TT there and went shopping with the DW for about 4 hours. They welded the cracks and fishplated the frame. It was a lot stronger when they finished. The owner of the frame company came out and talked to me. He said that the frame was not part of the TT warranty, it was separate and he expects the frame to outlive the TT. He also said if I had any other problems with the frame I should call him direct and they would fix the frame, no cost to me, for as long as I had the TT. Good Luck with the repairs.
Ernie Fortier
99 Bounder 34V
2 honda 2K paralled (for economy)
5.5 Onan onboard
96 Geo Tracker 4x4 Auto. convertable
Richard cheese
take her out to Wasco and Shafter
Posted: 10/29/09 09:42am Link  |  Quote  |  Print  |  Notify Moderator
lippert only gives a 2 year frame warranty, huh?
doesnt warrior lifestyles trailers use lippert?
my additude has a zeiman, which is warrantied for 10 years
mapguy
Puget Sound
Posted: 10/29/09 10:02am Link  |  Quote  |  Print  |  Notify Moderator
Might want to read the Zieman Frame warranty really closely. Zieman is part of Lippert Components Inc. and had a standard 2 year LCI warranty when we were looking at 2007/2008/2009 Attitude/Stellar units.
54ktmracer1
michigan
Good Sam RV Club
Posted: 10/29/09 10:59am Link  |  Quote  |  Print  |  Notify Moderator
sounds like lippert fixed it?
54ktmracer1
michigan
Good Sam RV Club
Posted: 10/29/09 11:00am Link  |  Quote  |  Print  |  Notify Moderator
oops reading the wrong post
Richard cheese
Posted: 10/30/09 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
bought mine in 04...it has a 10 yr warranty
jetboater454
FL
Posted: 10/30/09 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
Lippert,starting with '10 model year,only 1 year on frame.
"If momma not happy ....Who cares.I have my TH AND my toys .
Hookem2004
Milpitas, CA
Posted: 10/30/09 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
I had a cracked frame just above the third axle. Here is what it looked like. Value of Pre-Trip inspection Pt. 2
Anyways, I had a local welder do the repairs. Cost me $500 to redo all three axles.
2006 302 Skyline Rampage TH
2006 3500 Duramax CC/Dually
2004 2500 Suburban
2000 1950 Lund Tyee 200HP Yamaha HPDI
 > Cracked Frame
