kalynzoo
Los Angeles , California
I'd be afraid to let the ground dry into concrete, besides I don't have the patients to sit and wait. Think I would use ply re-enforced with 2/4s or thicker under the jacks to raise the tires and then glide a platform under the tires. Might even call a construction rental company and rent some steel squares. Wish you the best.
Hyall
Davie, Florida
Good Sam RV Club
DrivingMissDaisy wrote: On our very first trip with Miss Daisy I had the right rear tires break through the wet grass at Tipopike state park in virginia. I tried rocking it out, but stopped when the tires were sunk about half way to the rims. A couple of the maintenance workers went and got some assorted lengths of lumber. I raised the rear with the levelers, they slipped some lumber under the wheels, I raised the levelers and drove out. Simple as that.
It may be big
10-4 I did the same thing use the jacks with pads to raise the unit and chock the front tires
2007 Gulfstream TourMaster T40B MBE 926
2007 Honda CR-V
MC Honda VTX 1300R grey is faster
MC Shadow Aero 750 wife's
DON'T WORRY ABOUT NOTTIN - NOTTIN IS ALRIGHT
Horsedoc
Dixie --- N. Georgia
ditto on not using kitty litter. Talk about red Georgia clay, that stuff is made from Georgia koalin and is as sticky as red clay and slicker than owl poop. I have had trucks stuck in 1 inch of kaolin on an asphalt road.
Good luck on whatever your final decision to try is.
Daboo
Texas Panhandle USA
garry1p wrote: Read the fine print on the Good Sam policy I think you will find the road service does not cover stuck "off road".
beg to differ..they sent a big tow truck and got me out of the mud...i don't remember reading anything like that
Hello from the windy Texas Panhandle
Winnebago Adventurer 33V
Served proudly 1957-1965..U.S. Air Force
BobR
Aurora, Illinois
Roof shingles will work well. If you don't have any, cardboard will work.
Klueck
Georgia
OP here
We have left the MH where it was. It has dried up quite a bit in the last 24 hours. It's not stuck in real deep mud and only on the right rear tires. We placed some wood under the levelers, and jacked it up. We then put some boards under the rear tires and then raised the levelers. I didn't want to leave the MH jacked up the way it was for too long as it wasn't very level.
We decided to let it sit another day (or 2) and we feel we should be able to drive it out. Hopefully we won't have any rain.
We would have been ok if we hadn't tried to turn it around and back into our site. In the future if it's wet, it will go strait in.
Thanks for all the good suggestions.
I'll let you know how it works out. Hopefully tomorrow.
tropical36
Southwest Florida_USA
If it won't require more than a a little help, hookup a pickup truck and try to pull it out that way.
"We are often so caught up in our destination that we forget to appreciate the journey."
1998 36ft. National Tropi-Cal Model 6350, with a tag axle and one slide, on a 1997 P32 Chevy chassis....7.4 Vortec Engine
rjstractor
Auburn, WA
To the OP, if only the right tires are stuck, try applying just a little bit of brake as you drive out. A little tricky in a DP since the pedals are right next to each other but worth a try.
1998 Gulfstream Ultra B/H Ford E450 V10
2005 Chevy 2500HD 6.0 w/ Maxidump insert
6x12 Interstate enclosed trailer
7x16 Bulldog flatbed hauling a 2006 Kioti CK20 TLB
NEW (to us) 2006 Ford Escape Hybrid (not toad-ready just yet)
1998 Saturn SL2 toad
ChaosAgent
Wherever we are right now!
Good Sam RV Club
And exactly how often do people get stuck 'on road'?
Good Sam ERS has pulled me out twice in the last 2 1/2 years. Both times I was stuck in campgrounds when it started raining after I got there.
'99 American Eagle 40NS 'Beauty'
'04 Dodge Dakota 4x4 Crew Cab Toad
DH
DW
Mister & Emma - Designated Coach Cats
Our RV Adventures
