RV.Net Open Roads Forum: Class A Motorhomes: weigh station
 > weigh station
dantrim
Yale. MI
Posted: 10/29/09 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
I would like to know what the actual combined GVW of my MH and toad is. Am considering pulling in to a weigh station on the interstate and would like to know how they tell you your weight. Anyone tried this before?
2000 37' Pace Arrow
2006 Jeep Grand Cherokee toad
MichaelLaura
Little falls, N.J.
Posted: 10/29/09 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
those weigh stations are usuallt for big trucks. they only tell you your weight if your overweight, while at the same time writing you a ticket. they are for dot use. go to a truck stop and look for a certified scale. youll get your numbers there and wont have to deal with state police.good luck.
Michael * Laura
* Katelynn *
Little Falls N.J
2007 Emerald Bay 29 TREB by Gulfstream
2005 Chevy 2500
"It't not about where you've been, it's about where you're going!"
old guy
Oregon (pronounced Or e gun)
if you look out in front of your vehicle say about 10 to 15 yards, there will be a digital read out of your weight as you roll across the scales.
skipnchar
Topeka Kansas USA
Posted: 10/29/09 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
Most states will just run you out again. why not stop at a CAT scale and just PAY the $8.00 to get your weights.
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
retiredvegasmetrocop
Yelm, Washington
Good Sam RV Club
Posted: 10/29/09 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
RV's do not have weight limits by any statute. Only commercial vehicles have an enforceable weight limit. So........there will be no ticket. You won't make the officers happy though since the weigh stations are only for commercial vehicles.....and I'd guess the truckers may frown a bit also..
Joe Greenwood
2007 Monaco Camelot 42PLQ
2003 Ford 250/350 C/C 4X4 S/D V10 4.30
2004 Subaru Forester XT 5spd turbo AWD, toad for the Class A
2008 Chrysler 300 Touring
2005 Honda Goldwing GL1800 w/Motor Trike conversion
Goodturn
Ontario Canada
Posted: 10/29/09 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
Your local landfill or gravel pit may let you run through at no charge. I've run through the highway scales, but only when they're closed and no one is around. There is usually a digital readout. I've also used the cat scales and find them to be the easiest and no hassle from anyone. This way you get a print out with your weights.
dalehelman
Liberty Lake (Spokane) Wa.
Good Sam RV Club
Posted: 10/29/09 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
In Washington state when the truck scales are closed the scales still operate. That may be the case in your state. I would not enter if they were open.
Dale & Sandi
2006 Jeep TJ 4.0 w/33s and 4" lift
Stay In Play Toad braking system
2005 32S Terra Workhorse 8.1
2007 Yamaha powered dune buggy
Liberty Lake (Spokane) WA.
Air levelers(DIY for around $20)
Sewer solution
DIY under $50
dentmac
Southern Ontario, Canada
Posted: 10/29/09 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
Motorhomes can be overweight and illegal for two reasons.
ONE: over their GAWR - This is illegal and subject to fines and even removal of licence. A government scale could issue a fine.
TWO: over DOT permissible axle weights. 20,000 lbs for any single in almost all states. A few have a grandfather clause that allows up to 22,000lbs. 34,000 lbs for a tandem axle. This is also illegal but enforcement is weak so far. Ohio turnpike and parts of the PA turnpike will disallow overweight motorhomes.
Many states and provinces will allow motorhomes to be weighed . They will wave you on or do your weight. no problem and No charge. some are left "on" at night and after hours and can be used
routeforty
ohio
Posted: 10/29/09 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
Is there a local feed store? The ones around here only charge about five bucks, a lot cheaper that CAT scales. Gary
'05 chevy 3500, duramax, allison, '00 Coachmen Futura 2790 TT, 35th anniversary edition, 05 lance 1130-stable lift
vfrmarc
Ohio
Posted: 10/29/09 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
Many Flying Js have scales also. I weighed my Class A at one of two nearby stations. It was either $7 or $8.
 > weigh station
