RV.Net Open Roads Forum: Class A Motorhomes: Flat tow without removing battery fuse
 > Flat tow without removing battery fuse
wallynm
Los Alamos NM
Posted: 10/30/09 06:32am Link  |  Quote  |  Print  |  Notify Moderator
You will not lose any electronic setting by removing the correct fuse. Not sure what you mean by battery fuse as in our Suburban it is the ignition fuse per the manual.
tthrower wrote:
I'm going to be setting up a 2010 Acadia for flat towing and haven't towed before. The auto manual says to remove the battery fuse to avoid running the battery down. Is there another way to handle this so that the radio and other electronics settings won't be lost each time I remove the fuse?
Thanks
Terry
DONATE THAT OLD CELL PHONE TO SUPPORT SOLDIERS click here
Have a Cat Engine Yahoo Group or Cat RV Club Web Page
Have a Freightliner Yahoo Group or FCOC Web Page
2002 DSDP 3567 PUSHED BY KITTY KAT
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
brobox
Sunny SW. Florida
Posted: 10/30/09 06:47am Link  |  Quote  |  Print  |  Notify Moderator
Check on your Acadia and see if you have a steering wheel unlock position without have to turn the key to Acc. If you do, then there is no reason to pull any fuses or worry about charging. Many of the new vehicles, mine included, can unlock the wheel before before the Acc. "click" That is where I tow mine and no problems.
Chuck
02 Travel Supreme, 2 street side slides
09 Toyota Tacoma 2WD
JTrac
Oklahoma
Good Sam RV Club
Posted: 10/30/09 06:49am Link  |  Quote  |  Print  |  Notify Moderator
We've been towing our 08 Acadia for 2 years now. Pulling the 50 amp fuse is not a big deal and the only thing you loose is the clock setting on the radio. I can reset it in probably less than 30 seconds. We used a BrakeBuddy for a while and never had a problem with it working off the battery. We now have an SMI Air Force One system that requires no juice unless their is a disconnect. The only time I ever had a problem is when I accidently left the key in the run instead of the accessory position. Even with the fuse pulled a bunch of things were on and the battery was dead when we got to our destination.
Our 08 will not unlock the steering as suggested by brobox. That is a good idea if it will work for you.
JimT
J Walker
Oakton, Va
Posted: 10/30/09 06:50am Link  |  Quote  |  Print  |  Notify Moderator
My 2009 Malibu recommends removing one fuse, ignition sensor, to prevent running down the battery. Since it is not convenient to get to the fuse and remove it I have not done so. So far in one day towing there are no problems. I run a Brake Buddy from the car battery also so the drain from the ignition sensor is surely less than that. I am curious though and may measure the ignition sensor drain. It is continuous and leaving it on overnight in a multi-day tow might add up.
Jim Walker
2000 34' Damon Ultrasport DP
2009 Malibu
Brake Buddy
newxmar
East Otis, MA
Posted: 10/30/09 06:59am Link  |  Quote  |  Print  |  Notify Moderator
Have towed a Honda CR-V for a number of years without removing a fuse or having supplemental wiring. First, have a premium high amp battery, watch the battery voltage by a cigarette lighter plug in voltage meter, turn off the braking system (SMI)and key at night, and do the required proceedure 3 minute run each morning which keeps the battery up.
I do carry one of those emergency batteries just in case. Have let the engine run in neutral for a while when towing to charge the battery--when I forgot the icebox and left it on draining the battery.
So, no fuse to mess with and the radio keeps the settings.
ShapeShifter
Buffalo, NY
Posted: 10/30/09 08:17am Link  |  Quote  |  Print  |  Notify Moderator
tomousecap wrote:
Use a 30 or 40 amp fuse at both ends generator and fuse block for safeties sake as they are both hot terminals.
An important point about fusing both ends. This isn't your typical load circuit with only a single power supply.
I have a charge line as part of the wiring for my US Gear braking system. Their design uses a 20 amp self-resetting circuit breaker on each end. The value, of course, depends on the gauge of the wiring and the ratings of the connectors. So whether you use 20, 30, or 40 amps will depend on your setup details.
I like the idea of the resetting circuit breaker since there could be significant charging current when first plugging in. For example, if the toad battery is low, and you start up the MH, the voltage difference could be enough to want to drive more than 20 amps into the battery. With a fuse, it would be all over. But with the circuit breaker, it will cycle on and off every few seconds, preventing the wire from seriously overheating, but still providing some current to the toad, allowing it to slowly charge. (Or at least, that seems to be the theory.)
2007 Holiday Rambler Endeavor 40PDQ
400 ISL Cummins/Allison
2002 Chevy Avalanche toad
Inside: Him, Her, and a pack of little furballs...
BaldyD1
Central Florida area
Posted: 10/30/09 09:38am Link  |  Quote  |  Print  |  Notify Moderator
We do not pull any fuse, just start the dinghy and go through any required procedure when we stop (lunch, rest break, or fuel).
Speedy, Jackie & Dusty {Shih-Tzu/Maltese}
2006 Kountry Star KSDP 3912
2005 Saturn Vue (dinghy)
LVJ58
Las Vegas, Nevada
Good Sam RV Club
Posted: 10/30/09 10:22am Link  |  Quote  |  Print  |  Notify Moderator
Is the wiring such that you can install an in-line toggle switch or other type switch to render an open circuit while towing?
Jim & Sherry Seward
Las Vegas, NV
2000 Residency 3790 V-10 w/tags & Banks System
2003 Suzuki XL/7 toad
jbuening
jacksonville, fl,usa
Good Sam RV Club
Posted: 10/30/09 10:35am Link  |  Quote  |  Print  |  Notify Moderator
My Acadia book says to pull the 50amp Ign fuse. I do it because it says to and the only ting I have to reset is the clock and the volume speed compensation control setting. It takes 20 seconds to do this.
Jack Buening
Jacksonville, FL
tallyo
Fort Myers,Florida
Posted: 10/30/09 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
Wonder how you determined there is "no reason", when the factory/ manufacturer of his vehicle recommends he pull the fuse?
Tallyo
2007 Winnebago Adventurer
W-24, 6 spd Allison
Saturn VUE w/ Brake Buddy Vantage
Drinks-6, Eats-4, Sleeps-2
Semper Fi
