RV.Net Open Roads Forum: Class A Motorhomes: Onan Won't Run
 > Onan Won't Run
thorn2
georgetown, ontario
Good Sam RV Club
Posted: 10/30/09 08:40pm Link  |  Quote  |  Print  |  Notify Moderator
I have an 02 DSDP with a 7500 Watt Quiet generator. It has always run well, but now will not run. It will start and run for approx. 2 seconds and quit. I brought the coach to Eastern Canada Cummins-Onan. They thought it must be an electrical problem not associated with the actual generator and suggested I take it to an RV dealer, which I did. He spent 8hours and bypassed all external electrical, including oil and fuel sensors. The result was the same, so it appears it must be in the generator. Any ideas appreciated.
wilanddij
CA Desert
Good Sam RV Club
Posted: 10/30/09 09:08pm Link  |  Quote  |  Print  |  Notify Moderator
If it was a gas generator, I'd say the carb is varnished up and needs to be broken down for a thorough cleaning. That's the way mine acted when I let gas sit too long in the carb.
I don't know what happens with diesel if it isn't exercised regularly, but the injectors may be something to look at.
Will & Di
2004 Southwind 32VS
Workhorse/8.1
Jeep Wrangler/Blue Ox
"We have met the enemy, and he is us" Pogo
Jim@HiTek
Gresham, OR, USA
Posted: 10/30/09 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
I have heard of this problem before but don't remember what the solution turned out to be. Perhaps a search here on the forum might wield a result that helps.
Meanwhile, there is a bank of relays and an electronic control that can cause this symptom. I whack my relay box with a rubber mallet to get mine to run, but I don't think that would help you. But you never know.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Fleetwood Bounder, '94
Cummins Diesel, 190HP, 36.5'
Black Rock Lava Park, Nevada
Norm Payne
Livingston, TX
Good Sam RV Club
Posted: 10/30/09 09:15pm Link  |  Quote  |  Print  |  Notify Moderator
When it dies it should give an error code. Are you getting a code?
Norm
2005 Dutch Star 4015, Cummins ISL 370 hp
2007 Honda CR-V
See Ya Down The Road
http://www.seeya-downtheroad.com
rv2go
Fulltime between Knoxville, TN and the coast.
Good Sam RV Club
Posted: 10/30/09 09:19pm Link  |  Quote  |  Print  |  Notify Moderator
It will start and stop instantly with little or no oil pressure...
Or a bad oil pressure switch.
Winnebago Journey
TN Lic. RV 2 GO
1995 2dr. Hard Top Geo Tracker
www.rv2go.us
I'm here #4335
Travel Photos
Gadget Guy
Whitefish/Calgary
Posted: 10/30/09 10:16pm Link  |  Quote  |  Print  |  Notify Moderator
What is the code that it gives you???? The switch should be blinking when it shuts down. Touch the bottom of the switch, it will then blink your trouble code. First it will blink 3 times followed by some more blinks. Count the number. If it blinks 3 times, pauses and blinks 8 times, the code would be 38. Then look it up in the manual to give you an idea what the problem is. 38 happens to be high amperage draw which the recommended solution is to decrease the load. In my case it was a fuel problem. I am not suggesting that yours is but in my case it was. New fuel pump and I was good to go. This is just one example but the code will at least give you a starting point.
hottubkid
SCHAUMBURG,IL
Posted: 10/30/09 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
I would start by changing the oil filter and oil and go from their
hottubkid60193@yahoo.com
2004 SOUTHWIND 36E Tow 2003 CRV
f.wernlein
Northern Virginia
Posted: 10/31/09 05:05am Link  |  Quote  |  Print  |  Notify Moderator
I have a Onan 7000 Marquis....and recently was steered to this web site. Offers a great troubleshooting guide and sells parts:
http://www.flightsystems.com/pdf/onanrvtshootgd608.pdf
Good Luck
Frank W.
1985 BlueBird Wanderlodge
rgatijnet1
Good Sam RV Club
Posted: 10/31/09 05:13am Link  |  Quote  |  Print  |  Notify Moderator
Do you have plenty of diesel fuel? My generator stops when the main fuel tank level gets down to about 3/8 of a tank.
st687
tampa Fl
Posted: 10/31/09 05:23am Link  |  Quote  |  Print  |  Notify Moderator
Have you checked the fuel line for cracks,sounds like it is sucking air.
Doris &Bill
97 U270 Foretravel
05 Saturn Vue 265HP
University of Parris Island March 1966
Semper Fi.
 > Onan Won't Run
