btcruzer
missouri
sidewall of tires give MAXIMUM tire pressure to use with MAXIMUM load but how does one decide what pressure to run with actual load? My case is a hauler with a dry weight of 5200#, minimal water, dry holding tanks, average food/supplies and no toys. Tires says 2540# at 65PSI. if the load per tire is 75% of max rated load per tire would you run 75% on max pressure?
wild bill
Mira Loma, Ca. USA
I would run the 65 psi...better fuel mileage, less tire heat and ready for load when you need it.
05 Dodge 3500 Q-Cab,GearVendor 8 Sp,PacBrake,Banks intercooler & intake,TST R49,Transferflow 70 tank,TrailerSaver Hitch,05 Raptor 3612,Second AC, solar 6 battery sys Xantrex 3000, WEB SITE
http://home.earthlink.net/~wbrown02/wildbillwashere22/index.html
JFG
TN
Trailers should be run at the tire pressure on the side walls
Fred
coolbreeze01
Redding, Ca
Max air and two spares.
2008 Dodge 3500 CTD LB SRW 4X4 6-Speed Auto
P3 Blue Ox Sway Pro
2007 Komfort 212
skipnchar
Topeka Kansas USA
You MIGHT get by with lower pressure if your tires are over-sized for the load they're carrying but what would be the advantage in doing so? My advice is to fill your load range D tires to their max. If they're Chinese manufactured tires they'll blow regardless of the pressure you run and if they're GOOD tires they'll last a long time before the tread wears out or age requires they be replaced.
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
btcruzer
missouri
skipnchar wrote: You MIGHT get by with lower pressure if your tires are over-sized for the load they're carrying but what would be the advantage in doing so? My advice is to fill your load range D tires to their max. If they're Chinese manufactured tires they'll blow regardless of the pressure you run and if they're GOOD tires they'll last a long time before the tread wears out or age requires they be replaced.
My pickup came with tires with a max. inflation of 80#. When inflated to that pressure it rode like an iron wheeled lumber wagon. I ran more like 40# PSI for better ride, after 9 years the were doing fine when I traded.
the ride quality isn't a consideration with the trailer. But a balloon blown up tight is much easier to "pop" than a flabby one. This time of year heat buildup is not a worry and this shakedown run will not be a long trip. I've always thought of MAXIMUM as just that. The trailer is rated at around 10,000 and that works out pretty well at 2450 per tire @60PSI. My doctor said a MAXIMUM of 6 beers per day, but I don't always drink that many and he doesn't insist that I do.
BobWanderer
Perris,Calif,USA
btcruzer wrote: My doctor said a MAXIMUM of 6 beers per day, but I don't always drink that many and he doesn't insist that I do.
I will volunteer to finish off the Beers you don't consume
Seriously, I run 75 PSI in our T H with load range "E's", your not going to wear out trailer tires, they blow out, rot out, or get non repairable flats well before they wear out.
I work with a large fleet of trucks/trailers/etc, i can't say I have ever seen a trailer tire wear out from overinflation.
I guess you could go to the scales and get individual weights on each tire, then calculate the proper pressure based on those weights.
I say tire weight and not axel weight, because there could be a large difference. I understand the "baloon theory", but sidewall flex will cause heat buildup, which is NOT good on any tire.
Good luck
Bob J
2008 GMC 2500HD 4X4 DMax CC LB
2004 Thor Wanderer Wagon 247WTB
2006 TE450 Husky
2007 Rhino Sport Edition
2008 KTM250XCF-W
MEMBER AMA and CORVA
coolbreeze01
Redding, Ca
I like your Dr., but now I recommend 3 spares.
lincster
Mesa Az
Always run ST tires at max pressure. They suck as it is, so max pressure helps them live a little longer.
2006 F350 PSD CC 4X4 Dually w/Tow Boss package to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
btcruzer
missouri
OKAY, I'm convinced ---- 6 if favor of max pressure. Thanks for the input, guys.
