Alex Badiuk
Victoria Canada
Good Sam RV Club
Thanks guys for all the info the manual says type A ,if that's what's in the sump it's clear, maybe it is hydraulic fluid, I'll phone Lippert to check. The sump was sent from KEYSTONE LOW, so just want to add acouple quarts.As a retired engineer I am reluctant to add or mix unknown fluids together,it can be very costly down the road.
thanks again fellas
AL
Mile High
Lone Tree, CO
hahaha - ya let us know which brand of cheap transmission fluid you end up using after you talk to Lippert.
richfaa
Ohio
BTW.. The fluid level is checked with he slides IN and should be like 1 inch from the top of the reservoir
06 Montana 3400. 08 Ford F-350 6.4L
redsb3
Tucson
Good Sam RV Club
richfaa wrote: BTW.. The fluid level is checked with he slides IN and should be like 1 inch from the top of the reservoir
That depends on the manufacturer and how the slides were installed. If all Lipperts are the same, than OK, but generic information like that is not always correct. On my 5W, the living room slide has to be out, the bedroom slide in to check fluid levels.
2005 GMC Sierra SLT CC/SB with 6.6L Duramax/Allison
2002 Automate 5W, 32 ft, 13,280 GVWR
Valley Glider Hitch
Alex Badiuk
Victoria Canada
Good Sam RV Club
Just heard back from Lippert about the type of fluid in the slide out tank and they say it's okay to mix Type F auto trans fluid with what's in there, so thanks for all your suggestions
Alex
richfaa
Ohio
That depends on the manufacturer and how the slides were installed. If all Lipperts are the same, than OK, but generic information like that is not always correct. On my 5W, the living room slide has to be out, the bedroom slide in to check fluid levels. '
That is true....However the reply was not generic. The OP stated he had a 2009 Montana and the reply does apply to the Montana..That is why I posted it.
SuperdutyII
AZ
redsb3,
Where did you get the information about what YOUR slide situation had to be for checking the oil?
edited 11/02/09 04:05pm by SuperdutyII *
Duck
Miami Lakes, Fl
Good Sam RV Club
When our trailer was new we opened all the slides and marked on the reservoir the fluid level. We then closed all the slides and did the same thing. This was done with the help of the dealer at the PDI.
Don
08-FORD F350 PSD
08-Hitchhiker II 34.5 UKSBG
SuperdutyII
AZ
Duck,
You have a very good dealer if the reservoir was filled properly to begin with.
Alex Badiuk
Victoria Canada
Good Sam RV Club
My manual says all slides in and tank should be filled to 1 inch from the top(Montana).
