dicnic
Boynton Beach, FL
Good Sam RV Club
Not from me, but from our Motorhome! When going down the road, it seems like all the noise is coming from where the inside plastic molding touches the windshield and where the plastic pieces of the dash fit together.
These noises are pretty annoying. I have tightened all the screws, even replacing some with larger sizes to keep everything snug. But, the problem seems to be the hard plastic rubbing against whatever it touches (other plastic, the inside of the windshield etc.)
I would appreciate suggestions as to what to do to eliminate such noises.
TIA
2001 National Tradewinds LTC, 2005 Jeep Liberty Limited toad, M & G air brake, Blue Ox base plate and tow bar.
One "Bald-Headed Old Guy" (me),
One "Jewish-American Princess" (DW)
Two Birman Cats, "Mocha" & "Coco"
427435
Rochester, Mn
Spraying the joints with silicon helps.
Mark
2000 Itasca Suncruiser 35U on a Ford chassis
2003 Ford Explorer toad with US Gear brakes,
ReadyBrute tow bar, and Demco base plate.
rolnhome
Pacific Northwest / Mexico
On my last drive I came up with noises I had never heard before. I tightened this and that; and filed plastic I thought was rubbing. I finally, almost by accident, found this
and this
one is directly under the driver side dash/floorboard the other is under the passenger dash/floorboard. Once these are repaired I think the cockpit noise will be gone.
We're in Arizona
Executive
Northern California
rolnhome wrote: On my last drive I came up with noises I had never heard before. I tightened this and that; and filed plastic I thought was rubbing. I finally, almost by accident, found this
Wow... good catch..silicone wouldn't fix that.....Dennis
Dennis and Debi
Monaco Dynasty Baron 40PFD
Towing a Chevy HHR W/
ReadyBrute
BRAVE
Maine
All motorhomes creak and groan to some degree. Silicone, sprayed madly, does help for a while. Ear plugs are good and turning up the radio is a trick used by many seasoned RVers. The hard part is getting the silicone into the regions that are causing the noise. You may have to remove some of those screws and blast away. Personally, I'm hoping that as I get older, my hearing will continue to deteriorate. Thus, by 2020, our motorhome will be as quiet as a church.
Jack
Jack and Julee Meltzer
The RV Makeover Bible
jomarfl
Lakeland
Lol Dennis!
Papa JT & Mother Mary
Living The Good Life In Florida
Retired Military, USAF
2008 Fleetwood Fiesta LX, 34N w/bunks
2008 Hyundai - Toad
2005 EZ-GO Golf Cart
PackerBacker
Home is Montreal Qc & Seasonal is NY Adirondacks
I had a creak/rattle that I would have sworn was coming from the front right passenger area towards the dash. It's funny how one can interpret noise but in the end it turned out to be the entry door latch; a small adjustment and no sounds any more.
Eric
2009 Holiday Rambler Admiral 33SFS (34' 3")
2008 Jeep Liberty - North Edition
FQCC/Camping Quebec, KOA, Good Sam, Coach-Net
My Photos
blackf3504dr
Leesburg , FL. .Lake
You may try cutting felt into strips and putting them between the offending pieces of plasting then tighten the screws ....
Mom , Dad , Scooter & K.C ( killer cat )
'96 F350 4dr. Dually, 7.3 5sp.
'92 Holiday Rambler 34'
REAL TRUCKS DON'T HAVE SPARKPLUGS !
robatthelake
Vancouver Island
It is really hard to pinpoint Squeaks while driving down the road. It is even harder to do when the thing is parked! You have to have a Co-Pilot to take care of those sorts of little problems.
Rob & Jean
Dutch Star Diesel Pusher ..Tracker 4X2
deereone
NE
I went as far as removing and re-fitting some of the plastic (especially around the TV over the dash). I would say we reduced the sounds by at least 50% or more.
