RV.Net Open Roads Forum: Class A Motorhomes: F53 Chassis - Service Bulletin
 > F53 Chassis - Service Bulletin
fire-escape
Sorrento, BC
Good Sam RV Club
Posted: 11/01/09 09:22am Link  |  Quote  |  Print  |  Notify Moderator
I've been reading the bullteins relating to my 2000 F53 chassis and came across this: "Service Bulletin #: 020909; Date Added: 2002-12-06
Summary: EXCESSIVE AMOUNT OF WATER INTO THE AIR FILTER AND A LOSS OF POWER WHILE DRIVING IN THE RAIN. 1999-2004 SUPER DUTY F-53 STRIPPED CHAS."
My question, since I didn't see a recommended remedy, is what steps, if any, have others taken to avoid the problem (other than not driving in the rain)?
don/lou
Brandon MB Canada
Good Sam RV Club
Posted: 11/01/09 09:32am Link  |  Quote  |  Print  |  Notify Moderator
Ford Has a fix for this
Suggest you do a search under water injestion on F53 -This has been covered many times here on forum
I highly recommend getting the parts as it happened to me coming over the confederation bridge -not the best place for it to happen
Sorry cant find the part nos for this fix but ford has them
Don & Louise
2000 Coachman Catalina 330 MSB /F53
Rear air bags, 4 Koni FSD Shocks & Davis Front TruTrac
2008 Impala- Remco Lube Pump , Blue OX tow bar & Brake Buddy
don/lou
Brandon MB Canada
Good Sam RV Club
Posted: 11/01/09 09:43am Link  |  Quote  |  Print  |  Notify Moderator
Found this infoThis article supersedes TSB 02-09-09 to update the Service Procedure and affected model years.
ISSUE:
Some 1999-2004 F-53 Stripped Chassis vehicles equipped with a 6.8L engine, may ingest water into the air filter while driving in the rain. This can cause loss of power and/or engine stumble.
ACTION:
Replace the air cleaner inlet tube with a revised tube and strap. Refer to the following Service Procedure.
SERVICE PROCEDURE
Remove and discard existing shield. 2002-2004 model year vehicles are equipped with a long shield (Figure 1) and 1999-2001 model year vehicles are equipped with a short shield (Figure 2).
Figure 1 - Article 04-24-22
Figure 2 - Article 04-24-22
Remove and discard the existing air inlet tube. To remove, grasp the air inlet tube at the bottom of the air cleaner assembly and pull downward.
Remove and discard existing retention strap.
Install revised air inlet tube into the bottom of the air cleaner assembly and secure with revised strap (Figure 3).
Figure 3 - Article 04-24-22
PART NUMBER PART NAME
XC3Z-9F843-AA Air Intake
XC3Z-9E618-AA Strap
dbates
Marion, Indiana
Good Sam RV Club
Posted: 11/01/09 10:15am Link  |  Quote  |  Print  |  Notify Moderator
Click HERE for Ford's last fix for this problem. The price for this part has gone from under $20 to over $40 over the years. It has worked fine for my MH but some have posted that the opening lined up with the top of the front engine compartment opening & water still got in. They just added a small plastic extension on the front of the air intake to correct that problem.
By the way with the above instructions it's not hard to install this yourself.
Dave
Plus New Brunswick, Prince Edward Island & Nova Scotia
fire-escape
Sorrento, BC
Good Sam RV Club
Posted: 11/01/09 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the info - I'll be on it this week. I was using allworldauto.com as the source for TSB's but never did find the solution. Either I'm using that site wrong or I'm using the wrong site as a resource for TSB's
6string
Springfield, Illinois
Posted: 11/02/09 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
I installed the snorkel on my 2002 Infinity and if I drive all day in the rain I still get water in the intake. Just wanted to let you know.
