tedbohley
michigan
Good Sam RV Club
One of my leveling jacks will not go up by itself. I have tried wd40 on it and no luck! I can get it to go up with a 2x4 as a lever but not by itself,I wonder if a newer stronger spring will work? any Ideas.
Ted
klm
SIOUX FALLS, SD
Good Sam RV Club
What brand jack? I had the same thing with my right front hwh jack. Like you, I was levering it up with my trusty 2x4. The first and least expensive fix was to replace the springs, and at first that seemed to do the trick. But, not to be. Ended up replacing the jack. It took 6 weeks!!!!!! HWH has laid off a lot of its work force, so the wait time for parts is 4-6weeks.
'02 KOUNTRY STAR DP
'04 PT CRUISER INFERNO RED
LUCKY THE TRAVELIN'BLACK CAT
Doug and Cassi Glass
Clifton Forge, VA
Good Sam RV Club
If you're at home in MI the retraction will take a long time. Cold weather dramatically affects the time to retract. I usually push my r/f up with a board when I get tired of waiting.
New springs will help if yours are old.
Lay on the groung and get the model and serial numbers off a front jack and a rear jack. If they're HWH call them with that info and they'll sell/send you the proper springs. Different springs for different sized cylinders.
dougrainer
Carrolton, Texas
You have HWH jacks. IF you have to use a pry tool to raise the jack, then the upper internal seal is defective on that jack. You have to replace the jack cylinder. Either send it to HWH for a rebuild or buy a new one from HWH. Rebuilt is cheaper. New springs will not help your present problem. A correct functioning HWH jack---You can raise by using hand pressure. Doug
BRAVE
Maine
"You have HWH jacks. IF you have to use a pry tool to raise the jack, then the upper internal seal is defective on that jack. You have to replace the jack cylinder. Either send it to HWH for a rebuild or buy a new one from HWH. Rebuilt is cheaper. New springs will not help your present problem. A correct functioning HWH jack---You can raise by using hand pressure."
Not necssarily. You may have a problem with the solenoid valve that controls that jack. Call HWH and they will help you to diagnose your problem.
Jack
Jack and Julee Meltzer
The RV Makeover Bible
dougrainer
Carrolton, Texas
BRAVE wrote: "You have HWH jacks. IF you have to use a pry tool to raise the jack, then the upper internal seal is defective on that jack. You have to replace the jack cylinder. Either send it to HWH for a rebuild or buy a new one from HWH. Rebuilt is cheaper. New springs will not help your present problem. A correct functioning HWH jack---You can raise by using hand pressure."
Jack
IF the jack retracts with a pry tool. the solenoid is open. If the solenoid was closed, then the jack would not retract at all. The solenoids do not "partially open or close". Doug (27 years of working on HWH jack systems).
JDelauter
Leesburg, FL, USA
If you go to the HWG webpoage you can download an 18-page manual that includes a dynamite troubleshooting section
Retired SMCM(MDV) USN 30 years
3 'Nam Tours
As of 11/04 Full-Timing with:
2003 Gulfstream Friendship, Quad slide
1 lovely wife
and 1 sassy Bichon
JDelauter@aol.com
go-rusty
Wilmington, DE USA
Good Sam RV Club
Try wiping the cylinder down with 4 0 (0000) steel wool and Dextron. Worked for me and now that is the fastest jack to come up. Learned that from a retired Master Chief.
bob@29154
Sumter, SC
Good Sam RV Club
My rt rear hangs sometimes. It is the solenoid sticking. It is located directly below the controls which you can see under the mh. I tap mine with a hammer and it pops and it goes up. I have been trying to run them up and down once a week and it doesn't stick.
McDuff
Sachse,Tx.
My rt front was the same. Just had new springs put on fronts and now they come up faster than they ever did before.
Spring kits were like $50/side, for that price I'd definitely start here.
Rather be Ridin' then Rollin'
Winnebago '03 UA 40E(wheelchair accessible)
'05 Chrysler T&C (Braun Entervan)
Roadmaster Blackhawk2
Remco Lube pump
