| Class A Motorhomes Related Tips |
Wilbur
The Woodlands, Texas
I do not have a wiring diagram for the "Air Horn" switch on the dash control panel.
Does the switch control the air pump; or,
Does it toggle between the factory electric horn and the air horn?
Where under the hood are the wires from the switch usually found or terminate?
What is the best/easiest way to trace the air horn switch circuit?
Any help is appreciated.
1995 Georgie Boy Cruisemaster
edited 11/01/09 02:20pm by Wilbur *
Doug and Cassi Glass
Clifton Forge, VA
Good Sam RV Club
My air horn switch is always on except in campgrounds in case I happen to bump it at night.
My regular horn works with a light depression of the horn and air horn works with a full depression, provided the "switch" is on.
My m/h is an Itasca, the year and make of yours will get you a rapid response from a fellow rig type owner.
horizon451
Henderson, NV
Good Sam RV Club
The dash air horn switch either arms or disarms the air horns.
'02 Itasca Horizon 36LD
'02 Jeep GC toad
