RV.Net Open Roads Forum: Fifth-Wheels: Tire bombs?
 > Tire bombs?
Fifth-Wheels Related Tips
ryanallie1
Magalia, Calif
Good Sam RV Club
Posted: 11/05/09 06:19am Link  |  Quote  |  Print  |  Notify Moderator
Hi All.
We just changed out our ST-205X75R15 Duros. The only reason we changed them is they timed out. They were a little over 5 years old. No cracks of any kind or un-even wear. Never had a single problem. Also have never had a tire Blow-Out in over 40+ years as RV'ers. We also have never had a Car or a Truck Blow a Tire either. Good Luck. Happy Camping. Dan & Jill
1997 Ford F-250, H.D. Extended-Cab, Short Bed, 7.3 PSD, K&N Air Filter, 5000 lbs air bags w/compressor w/guage, SuperChips Tuner/Programer. 1996 Nash 24fter 5er, 15K "Lil" Rocker Hitch w/BedSaver, Twin EU2000i Gen's W/Kit. Nam-Vet, 66-67-68,& 70-71
JIMNLIN
Big Cabin, OK
Posted: 11/05/09 06:48am Link  |  Quote  |  Print  |  Notify Moderator
I certainly wouldn't put any 15" ST tire under a trailer that heavy.
Do a search on ST tires on thie web or better yet do a google on ST (special trailer).
My 11200 gvwr 5er came with the same size ST ire. I don't use ST tires nor would I recommend anyone use them on a 12000 gvwr trailer. I upgraded to 16" wheels and LT E tires which will elimiate ST related tire problems and worries and big bucks for a TPS.
"good judgment comes from experience, and a lot of that comes from bad judgment" Will Rogers
'03 2500 QC Dodge/Cummins HO 3.73 6 speed manual Jacobs Westach Linex
'97 Park Avanue 28' 5er with two slides 16" BFG Commercial LTs
boiledcrabs
louisiana
Posted: 11/05/09 07:06am Link  |  Quote  |  Print  |  Notify Moderator
In this instance the age, size, rating, or brand of the tire makes no difference. They say made in Tiawan which is China so they will be a problem. In the last few years every tire I've had which was made in China has blown out long before age or mileage was an issue regardless of what service I tried to use them in. Last week I had another blow out on an equipment trailer while it was unloaded. The tire was G rated, had correct air pressure, less than two years old, and probably less than 2000 miles on it. It blew a hole straight though the center of the thread of the tire, not even in the sidewall. I have three or four more China tires on another equipment trailer which will be changed out Friday with Michelin XPS Ribs. It's not so bad to have a blow out on an equipment trailer but having them on a travel trailer often does some pretty good damage to the sides of the trailer. I will never chance a Chinese tire again.
I wouldn't buy anything from China if it were possible. I'm willing to pay more for products made in America!
RandACampin
Kathleen, Georgia
Posted: 11/05/09 09:06am Link  |  Quote  |  Print  |  Notify Moderator
I would be willing to bet that 9 out 10 products you buy every day are from China.
dmorgan
IL
Posted: 11/06/09 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
I do understand that these are poor quality tires. The part I don't understand is why the manufacturer would sell a product with a known under rated "D" tire. These tires were installed by the manufacturer. They would assume all liability by selling a defective combination of components and the first law suit would wipe out any profit they made by selling the less expensive tires. I also think the manufactures attorneys would want to protect their clients interests and advise them accordingly. JMHO .....So are my tires really under rated?
2003 F250 7.3 PSD
2008 Northshore 320TS-M5
Prodogy
Timbrens
Fifth Airborne Sidwinder W/Reese 16K
hoopers
Loveland, CO
Good Sam RV Club
Posted: 11/06/09 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
Besides the weight factor, most ST tires are rated at about 60 MPH max....that is one benefit of LT tires, as they are rated at higher speeds.
I upgraded my china tires for about 850 bucks, which included new aluminum 16" wheels. My wallet didn't like the decision, but I feel better for it knowing my tires can handle the speeds and loads.
Chris
Shelter Bay, Wa
Posted: 11/06/09 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
What you are failing to understand is that the trailer manufacture is out of the loop on tire warranty. Tire warranty is completely in the hands of the tire company just like every auto sold in the USA. It is a giant numbers game on the part of a the tire companies. And just try to take legal action against a chinese company!!!!
Chris
My Rig
2001.5 2500 STD CAB AUTO SLT 4x4, CTD 4:10's, Bomb'd to Tow
2005 Cardinal 29WBLX.
FastEagle
Taylors, SC
Good Sam RV Club
Posted: 11/06/09 10:17pm Link  |  Quote  |  Print  |  Notify Moderator
The manufacturer is required to match your axle rating with the OE tires. So if you have 5000# axles they have done that.
The automobile industry is head and shoulders above the RV trailer industry when it comes to providing reserve load capacity in their OE tires.
FastEagle
* This post was edited 11/06/09 10:23pm by FastEagle *
smkettner
Good Sam RV Club
Posted: 11/06/09 11:54pm Link  |  Quote  |  Print  |  Notify Moderator
No the tires are not under rated. Close to the max yes, under rated no.
With a ~2100 dry pin your axles at GVWR will carry about 10,000 max and the tires are rated 10,160. Most likely you are a bit under GVWR, yes? I would guess your axles are carring 8500 to 9000 pounds but you should weigh it to verify. The DURO radials seem to do OK. Read the trouble posts again and you will see bias or no designation. The radial posts seem to be good.
I would keep them aired up to the 65 psi max and run them for at least a couple years.
BTW all ST are rated 65mph.
jetboater454
FL
Posted: 11/07/09 05:21am Link  |  Quote  |  Print  |  Notify Moderator
Yep just go to Walmart.They are the largest importer in the world.Wish Sam was still alive,he would beat his kids a... for going foreign.
"If momma not happy ....Who cares.I have my TH AND my toys .
 > Tire bombs?
