toad and the toadett
NW Indiana
WE currently pull a 27 foot non slide TT and are thinking of adding a truck camper to the stable. We have a 2005 Chevy 2500 HD crewcab w/ 6.5 foot bed. Could we carry a pop up with an 8 foot floor if we didn't exceed the weight limit?
Thanks,
Toad
kohldad
Goose Creek, SC
There are numerous campers that are designed for short bed trucks. Most of them are pop-ups but there are also a few hard sides that will fit within your limits. Check out Palmino and Sunlite for pop-ups or the Lance for hard side. There are others, these are just the ones I can think of which will get you started.
Photo Albums (Congaree NP added 12/09/09)
2004.5 Ram 3500 4x4 Quad-Cab SRW CTD 6-spd
2004 Lance 815
1982 CJ-8 Scrambler - going, going, anyone
Loving wife, two horse crazed teenage daughters, two horses, two cats
Eycom
Fl to NY
Be mindful of the center of gravity of a camper. It should rest on or just in front of the rear axle. Otherwise, the steering can get a little light.
F-350 PSD
Lance 1121
adamboyd
BC Canada
You can do anything you want. It will look ugly though and it might not be safe, depending on the centre of gravity.
Arcticfox1
Nashville
Here is a 9' Arctic Fox 811 on a Ford F250 short bed.
adamboyd wrote: You can do anything you want. It will look ugly though and it might not be safe, depending on the centre of gravity.
How this for Ugly!!!!
I think she's purdy
AF1
racedrvr
Chicago Burbs
Not a problem at all. I have a Bigfoot on my Chev 2500HD. There are many hardside campers made for a shortbed truck. As with any truck camper/truck combo, weight will be a consideration. I looked at many different 8-9.5 foot campers designed for shortbed trucks. None of them had center of gravity issues, but many were at or above the trucks stated carrying capacity. This site is full of debates as to whether or not a little overloaded of the truck is a safety concern. Many on here do so with some minor truck suspension upgrades.
Chevy Silverado LT EC 2500HD 4X4 Duramax/Allison. Airbags, Rancho 9000X, Torque Lift/Fastguns, Hellwig swaybar, Hypertech Hyperpac, Honda eu2000i
Bigfoot 15C 8.2
Oldtymeflyr
Littleton, CO
The manufacturer of the camper will usually tell where the center of gravity is, and of course this is an important number. If it isn't designed for a 6.5 foot box this number is very important.
A 6.5 foot box can hold a camper that is approximately 6.5 feet to realistically about 8 to 9 feet of floor.
when you say flat floor probably available, depends on the design of the camper, some have heated tanks in the floor that then put a step at the door.
The problem with some of the bigger 6.5 foot units is the weight, it does add up.
We have a 2500HD 6.5 box and an Outfitter Apex designed for a 6.5 foot box. We looked at a Host designed for a 6.5 box, two slides, lots of room, just too big, been there done that. There are lots of options out there.
Good Luck.
mkirsch
Rochester, NY
It's simple: Just look for a camper that says "designed for short (standard) bed trucks" or other similar language that indicates that the camper is designed for a 6.5' bed.
woodyt30
Central NY
I have a Northstar 850sc that you can put on a long or short bed full size truck. And its a great camper too.
flaxi
Germany
I have an Adventurer 810WS + 2500 Dodge Ram 2500 Shortbox, COG is in front of the rear axel. So, no problem ! ;-)
Dodge CTD 2500/03 & Adventurer 810WS/04
GERMANY
