RV.Net Open Roads Forum: Class A Motorhomes: Beeeeeppp question
 > Beeeeeppp question
Greg_S
San Diego
Posted: 11/02/09 09:45am Link  |  Quote  |  Print  |  Notify Moderator
Always love the new sounds my coach makes. Happens very intermittently but enough that I wanted to see if anyone else knows what it may mean.
When making turns I will hear a long beep, 5-7 seconds, and then it does away. Its not the buzzer noise you get from the dash but more like a Co2 type beep. The coach drives and feels fine.
any ideas?
2002 Georgie Boy 37'DP
Thunder Mountain
Estes Park, Colorado
Good Sam RV Club
Posted: 11/02/09 09:48am Link  |  Quote  |  Print  |  Notify Moderator
I had a similar type of mystery alarm. Turned out to be low fluid in the leveling jacks.
2007 HR Endeavor 40'PDQ
HMS Indebtedness + 2001 Wrangler
BigSkyBob
Western Montana
Good Sam RV Club
Does anyone else hear it lol...
2008 Monaco Camelot 40PDQ, 4 slides, 2008 Dodge Ram 1500 Hemi Quadcab 4x4. Blue Ox, Garmin 7200 GPS, Doran Pressure pro on all 10, M&G Brake, 50 amp SurgeGuard, FMCA, Coachnet.
Once you're dead you have lost a very important part of your life.
Mr.Mark
California/Tennessee
Posted: 11/02/09 09:51am Link  |  Quote  |  Print  |  Notify Moderator
My first guess would be that you are low on Hydraulic fluid. When it happens, do you notice a light coming on your leveler pad?
MM.
Mr.Mark
2008 Monaco Dynasty, 42ft., 4 slides, 425 hp clean-air Cummins diesel
2007 Honda CR-V EXL, AWD, w/Nav and the M&G braking system
deandec
El Dorado Hills, CA
I had similar alarm when coolant in the recovery tank was low. Would only occur on hard turns when fluid would leave the sensor bare.
Dean
95 CC Magna, Jeep GC
jtfcons
Washington State (The dry side)
Good Sam RV Club
Posted: 11/02/09 09:58am Link  |  Quote  |  Print  |  Notify Moderator
Since it only happens on turns, I'll take a stab and say that when my turn signals are engaged and when applying power there is a distinctive pulsing buzz that comes from the turn signal flasher device. I have always assumed that the compression pulses from the diesel causing disturbance to the 12V system cause it because it only occurs when power is being applied (not at idle)and when turning (signal flasher on). Just a guess.
John & Sharon, 2 Daughters, 2 Sons-in-law, 5 GK
Scottish Terriers (Bonnie & Chloe)
1997 HR Imp., 38CDS, 1 Slide
325 Cummins C8.3Mech., MD3060, EBw/Cst.Sw.,
Toad-98Tracker 4X4 or 03GMC Envoy 4X4, Excallibar TB, Pressure Pro TPMS, Henderson Mot. Ctrl. Units
trop-a-cal
Palm Coast Fl
Posted: 11/02/09 10:15am Link  |  Quote  |  Print  |  Notify Moderator
If your rig has air ride it could be the compressor sending air to low side.
Greg_S
San Diego
Posted: 11/02/09 10:23am Link  |  Quote  |  Print  |  Notify Moderator
it does, if this is the case I should be able to see the level on the low side change?
yes, other people hear it :~)
no gauge lights come on
its a beep and not a buzz
coolant is fine
Chief45
Porterville, Calif.
Good Sam RV Club
Posted: 11/02/09 11:02am Link  |  Quote  |  Print  |  Notify Moderator
I would suspect the lever fluid. Its a common sympton.
kalynzoo
Los Angeles , California
Posted: 11/02/09 11:06am Link  |  Quote  |  Print  |  Notify Moderator
Could you be leaving your turn signal on for more than 3/4 of a mile, and the signal warning sound is activated?
