cleoent
San Jose
I'll take a look when i get home, thank you!
jackxclan
bakersfield
That swith may be to some small lights mounted above the kitchen cabinets.
Gun metal gray 07 new body style 3500 diesel crew cab 4x4 dually
red WW fsc 28 tiki hauler
red 400 ex
black 250ex
red 400ex
red 250ex
red KW heavy iron hauler
HOOLIGAN # 385
dirtbikeguy2003
Lancaster, Ca
Might be a step light? My Weekend Warrior has a small light under the steps that pull out.
2007 Weekend Warrior FSW3200
cleoent
San Jose
It's an exterior light. I have a feeling it's just wired wrong. I confirmed yesterday that the porch light comes on with the floods. So i'm going to take off and look at the wires. I was going to do it yesterday but the screws have a square head which i've never seen before. Is this a rv thing?
N-Trouble
California
The lighted red switches are generally exterior lights. THey do that so you don't crawl into bed accidentally leaving an exterior light on only to find your batteries dead in the morning. My 04 FK1900 does not have exterior flood lights and as a result I only have three red lighted switches (front, porch, rear) instead of four. Since you have floods I would agree that is what the fourth switch is for. It should be an easy fix once you get the screws off. Yes the square heads are all over your trailer. Best to go pick up a couple of bits at your local HW store.
Al/Reeni
Ft Myers, Fl
Not so familiar with WW, but my Rage'n has a power switch for the fuel station right inside the entry door.
N-Trouble
California
All of the WW's I have seen use a timer dial at the pump to turn on power
mapguy
Puget Sound
Al/Reeni wrote: Not so familiar with WW, but my Rage'n has a power switch for the fuel station right inside the entry door.
Yep, power switch on wall by entry door plus a timer next to the hose compartment.
cleoent
San Jose
my fuel station still works without that switch on... so i dont think that's it either.
thinkpt
Tustin, CA
derwud wrote: The 4 switches should be,
front light
porch light
door side floods (optional)
rear light.
yep, way mine is
2006 Chevy 2500 6.6L D/A
2007 WW FS2500, Billet etc
2006 Yamaha Rhino Special edition
2006 Honda Trx450er
2003 Suzuki quad sport 50
2008 KTM 530 EXC R
2002 Suzuki LT80
2002 Yamaha PW50
Son Ryan
