RV.Net Open Roads Forum: Class A Motorhomes: Newbie question....covering tires with what?
 > Newbie question....covering tires with what?
ArchHoagland
Clovis, CA, USA
Good Sam RV Club
Posted: 11/03/09 12:18am Link  |  Quote  |  Print  |  Notify Moderator
I use the Adco covers.
Got tired of the neighbors animals spraying my wheels and also any water splashing dirt up on the tires and wheels.
2004 Monaco
La Palma 36DBD
Two Slides
2 Potties
Workhorse 22 chassis
8.1 gas engine & Allison 1000 transmission
7.1 MPG based on fuel used over 32,000 miles
TOADS
US Gear Brakes
1991 Mazda Miata 5 speed 33MPG 2,310 LBS
harold1946
arizona
Posted: 11/03/09 03:16am Link  |  Quote  |  Print  |  Notify Moderator
I don't cover them I use 303 protectant. Just about anything that will stop uv should be fine. We are always thinking about storage space so we opted for 1 bottle of 303 that is used for many things as opposed to four covers that do only one.
Harold and Linda
2005 Airstream Land Yatch
Explorer toad
texasbaskets
Frisco, TX
Good Sam RV Club
Posted: 11/03/09 09:29am Link  |  Quote  |  Print  |  Notify Moderator
OP, those are usually vinyl covers made specifically for your tire size.
As for the reason, well, just do a little math.
Tire Covers = $85
New Tires = $3,000
Covering the tires to protect from UV makes perfect sense. If you don't now, you start the day after you replace your first set of tires because they cracked. (Mine lasted 4 years in this Texas sun.)
For professional guidance...
Go here and read page 7.
Or...
Go here and read page 5.
Goodyear says RV tires don't need covered, but just try to tell that to the people who've replaced them.
Storage pressure recommendations varied between those two manufacturers as well. I follow the ones for my brand.
Michael, Kay, and Prissy (The vicious Malti-Poo)
'05 Coachmen SportsCoach SE 372DS a.k.a. "Mana's Cabana"
PenMan
New Mexico
Good Sam RV Club
Posted: 11/03/09 10:41am Link  |  Quote  |  Print  |  Notify Moderator
Use the covers to keep UV rays off tires. Don't need to put wood or anything else between the tires and ground. Also don't need to over inflate tires. The covers also help keep tires and rims cleaner.
Chris and Jane and two boys who use a tent
2007 Rockwood Roo 23B
2006 Dodge Ram 3500, 4x4, Crew Cab, 5.9 diesel
1996 Harley Davidson Electraglide
