RV.Net Open Roads Forum: Any damage towing an automatic in neutral?
 > Any damage towing an automatic in neutral?
ShapeShifter
Buffalo, NY
Posted: 11/02/09 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
trop-a-cal wrote:
NO,NO,NO,it won't track in park, as steering will be locked!
Interesting. I've never seen a car that locks the steering wheel when the transmission is put in park. I've seen them where the steering wheel is locked and the transmission is locked in park when the key is removed, but that's independent of putting the tranny in park.
Which cars lock the steering wheel when you put them in park?
____
To the OP: on my truck (Chevy full size) I put the transfer case in neutral and the transmission in park. I don't have a steering wheel lock in that truck, so I don't have to worry about the key, but lots of people need to keep the key in the ignition to unlock the steering wheel. Many of those people also need to pull a fuse or two so the battery doesn't run down with the key in the ignition.
Every car is different, you really need to see what Chevy has to say about it. If it can be towed, there will be a description of the exact procedure in the owner's manual. For example, in my case, it's not enough to just put the transmission in park -- the tranny needs to be in neutral to shift the transfer case, then I have to put it in drive for a few seconds, then in reverse, and then I can finally put it in park.
So the moral of the story is you need to find out what works for your specific year and model, as the rules can change from one year to the next, and can vary depending on drive-line options you have. Generalities won't really get you anywhere. You need to find the answer in your owner manual, or from someone who has the EXACT same setup as you.
2007 Holiday Rambler Endeavor 40PDQ
400 ISL Cummins/Allison
2002 Chevy Avalanche toad
Inside: Him, Her, and a pack of little furballs...
bo caballero
sacramento
Good Sam RV Club
Posted: 11/02/09 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
Check owners manual and call a chevy dealer.
garry1p
Oklahoma
Good Sam RV Club
Posted: 11/02/09 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
To answer your question.
YES; you can damage the transmission if you do not follow the manufacture recommendation.
As someone else pointed out some units need fuses pulled most all 4X4 need transmission in park transfer case in neutral and requirements to pull 4 down change from year to year in the same models.
Garry1p
1990 Holiday Rambler Aluma Lite XL
454 on P-30 Chassis
1999 Jeep Cherokee sport
msmith1199
Central, CA
Posted: 11/02/09 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
omylip wrote:
If you put a Chevy S-10 4WD automatic transfer case in neutral, and then put the gearshift in neutral, would the S-10 suffer any transmission damage or create a drag on the motorhome over a long trip? Thanks all you experts!
Check the owners manual, but most 4x4's that allow towing four down state transfer case in nuetral and then tranny in park.
2004 National Tropi-Cal T-350, Class A, Triple slide, 330 HP Cat DP.
2006 Dodge Dakota 4x4 or
2002 Harley FLSTF Fat Boy on a Trailer or
2004 Polaris Quad on the Trailer
msmith1199
Central, CA
Posted: 11/02/09 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
trop-a-cal wrote:
Art D wrote:
IF it can be towed, I think you will find out that you put the gearshift in PARK with the transfer case in NEUTRAL. You don't want the tranny to spin at all. But check all this out before you do it.
No, No, No. Steering doesn't lock in park, it locks when you turn the key off. Every 4x4 owners manual with an auto-tranny that I've seen (including the three I've owned) says transfer case in nuetral, tranny in park, key in the acc position to keep steering wheel from locking.
Deen
Vancouver, WA
That's what our Jeep required. We don't have the Jeep anymore though.
BigSkyBob
Western Montana
Good Sam RV Club
Posted: 11/02/09 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
msmith has it right.
2008 Monaco Camelot 40PDQ, 4 slides, 2008 Dodge Ram 1500 Hemi Quadcab 4x4. Blue Ox, Garmin 7200 GPS, Doran Pressure pro on all 10, M&G Brake, 50 amp SurgeGuard, FMCA, Coachnet.
Once you're dead you have lost a very important part of your life.
The Texan
Summer: Cascade, Idaho - Winter: Quartzsite, AZ
Posted: 11/02/09 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
Not necessarily, mine say all that except, turn ignition switch to off, remove key and lock doors.
Bob & Betsy - USN Ret'd '78 & FL LEO Ret'd '03 & FT Class of 2002
'05 HR Endeavor 40PRQ, 400 Cummins -With-'05 GMC Sierra LT, CC, Z-71, the pusher & our Arctic Cat 500A & Suzuki KQ 400A, riding in or behind the pusher.
Where the wheels are stopped
wilanddij
CA Desert
Good Sam RV Club
Posted: 11/02/09 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
A search for "S-10" in the dinghy towing forum turns up all this info S-10. Maybe your answer is already here.
Will & Di
2004 Southwind 32VS
Workhorse/8.1
Jeep Wrangler/Blue Ox
"We have met the enemy, and he is us" Pogo
HIDEOUT
San Francisco Bay Area
Posted: 11/02/09 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
Our 05 Jeep Wrangler's owners manual states, tranny in park..Transfer case in neutral. My neighbor's 09 Wrangler doesn't have the tow position to unlock the steering on his ignition. He has to turn his key to accesory so he has to un-hook his battery before towing. Ours has a tow position which does not affect the battery. All the other steps are the same. So it is true that even the same models from year to year change the rules. As stated before, best to check the owners manual.
Kevin & Dawn
Doggies:
Persalina, We love you & miss you so very much!
Moonbeam
Chloie Pearl
'07 Itasca Suncruiser 35L
Workhorse 24-8.1 Vortec w/6 sp. Allison
05 Jeep Wrangler Toad
Roadmaster Even Brake
