RV.Net Open Roads Forum: Fifth-Wheels: Furnace would not work this week-end
 > Furnace would not work this week-end
Fifth-Wheels Related Tips
HODieselRam
Colorado
Posted: 11/02/09 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
Hey RVer's
I have a 2004 Larado 5er and my Suburban furnace would not work. It has ALWAYS worked everytime until this past week-end. I crank up the thermostat and nothing...just a click, no blower, no nothing
Any ideas ? I checked the fuses but that is all I checked.
Yes, we have the LP bottles topped off.
Thanks
03 Dodge 2500HD QQ HO CTD 48RE 4x4 SLT/16K Pullrite Superglide/Jordan BC/Magnaflow muffler/Firestone airbags/Edge EZ/Di/Pricol gauges Cubby mounted.
04 Laredo 29BH 31ft 5er/2 batteries/custom class III receiver hitch/DVD/loaded
enblethen
Moses Lake, WA USA
Good Sam RV Club
Posted: 11/02/09 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
Fan starting and then click would say you are looking at possibly a dirty sail switch.
Bud
Suzuki XL7 pushing Pace Arrow
HODieselRam
Colorado
Posted: 11/02/09 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
Fan//Blower never fires up at all. Thermostat perhaps ?
SDkid
Johnston City, Il
Good Sam RV Club
Posted: 11/02/09 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
check here and look under furnace trouble shooting
http://www.marksrv.com/furnace_trouble_shooting.htm
JR45
Warren/OR/USA
Posted: 11/02/09 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
How are the batteries?
06 F350 4x4 PSD Lariat FX4 CC LB
Coolant Filtration System
PressurePro Monitors
2003 Alpenlite Limited
Fifth Airborne
Ridgewood 30RK
3 Slides
ButteBumBob
Albuquerque,New Mexico, USA
Posted: 11/02/09 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
Just had the same problem on a 2004 Crossroads Cruiser....I had to replace the sail switch.
2004 GMC 2500HD Duramax/Allison/Shortbed/Crew Cab/ 4x4
2004 Crossroads Cruiser Fifth Wheel CF29RK
1973 Seeker Travel Trailer (for the short trips)
Hangin with the Big Boys
CrownandCoke
Kansas City, mo
Posted: 11/02/09 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
I have had the problem in the my Cougar, more than once. Try disconnecting shore power and battery power. This should reset it and start up.
HODieselRam
Colorado
Posted: 11/03/09 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
Bad sail switch would still allow the blower to fire up wouldn't it ?
So you had the same identical problem as me and it was the sail switch.
How did you check that the problem as the sail switch? No current to switch?
Also, disconnecting shore power and disconnecting the batteries might reset everything ?
Thanks for the replies
rick83864
Sandpoint, ID
Posted: 11/03/09 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
I give up, what's a sail switch???
06 Dodge 3500 Laramie 4x4 Dually
5.9 Cummins HO Automatic,Jacobs brake, Dodge Navigation
06 Grand Junction 34' Mor/ryde, 5500 Onan genny, Dual A/C, Fireplace
21500 GVW
enblethen
Moses Lake, WA USA
Good Sam RV Club
Posted: 11/03/09 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
If the fan does not start then there should be a resettable circuit breaker on the fan housing. Your late model rig probably has the time delay built on the circuit board. You didn't want to hear that did you? Dinoaur Electronics is a better circuit board.
Check the circuit breaker in furnace first.
Rick: A sail switch is a small microswitch with an arm that sticks into the fan assembly. When the fan blows over it, it closes to allow the burner to lite the flame.
