RV.Net Open Roads Forum: Fifth-Wheels: Furnace would not work this week-end
 > Furnace would not work this week-end
Fifth-Wheels Related Tips
ButteBumBob
Albuquerque,New Mexico, USA
Posted: 11/03/09 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
HODieselRam wrote:
Bad sail switch would still allow the blower to fire up wouldn't it ?
So you had the same identical problem as me and it was the sail switch.
How did you check that the problem as the sail switch? No current to switch?
Also, disconnecting shore power and disconnecting the batteries might reset everything ?
Thanks for the replies
When I moved the thermostat switch up.... all I would here is a click sound. I could bang on the top and sides of the furnace and it would fire up. I had to call a mobile service man to replace the switch. He told me this is a very common problem with the Suburban furnace. I think it is called a sail switch because there ia a little piece of metal in the switch that moves to make contact when the blower moves it "with wind" to make contact. The part was $21.00. Good Luck!
2004 GMC 2500HD Duramax/Allison/Shortbed/Crew Cab/ 4x4
2004 Crossroads Cruiser Fifth Wheel CF29RK
1973 Seeker Travel Trailer (for the short trips)
Hangin with the Big Boys
rick83864
Sandpoint, ID
Posted: 11/03/09 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
enblethen wrote:
If the fan does not start then there should be a resettable circuit breaker on the fan housing. Your late model rig probably has the time delay built on the circuit board. You didn't want to hear that did you? Dinoaur Electronics is a better circuit board.
Check the circuit breaker in furnace first.
Rick: A sail switch is a small microswitch with an arm that sticks into the fan assembly. When the fan blows over it, it closes to allow the burner to lite the flame.
Thanks enblethen , if it was a snake it would have bit me.
06 Dodge 3500 Laramie 4x4 Dually
5.9 Cummins HO Automatic,Jacobs brake, Dodge Navigation
06 Grand Junction 34' Mor/ryde, 5500 Onan genny, Dual A/C, Fireplace
21500 GVW
HODieselRam
Colorado
Posted: 11/04/09 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
I don't think its the sail switch. That switch signals the gas valve to open once the blower is up to full speed or 75% I think. My blower wont even power up.
I will have to trouble shoot this over the week-end. Thanks for all the help. I will report my findings later. Thanks again
03 Dodge 2500HD QQ HO CTD 48RE 4x4 SLT/16K Pullrite Superglide/Jordan BC/Magnaflow muffler/Firestone airbags/Edge EZ/Di/Pricol gauges Cubby mounted.
04 Laredo 29BH 31ft 5er/2 batteries/custom class III receiver hitch/DVD/loaded
enblethen
Moses Lake, WA USA
Good Sam RV Club
Posted: 11/04/09 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
The blower not powering up could be the time delay relay. Depending on exact model it could be on the circuit board. Earlier models have it separate. You could look it is about one inch cube with two small and two larger connectors.
What is the model of your furnace?
Bud
Suzuki XL7 pushing Pace Arrow
jimwooster
Wooster, Ohio
Good Sam RV Club
Posted: 11/05/09 11:13am Link  |  Quote  |  Print  |  Notify Moderator
I know if my unit has set for awhile with the gas turned off it takes some effort to get the propane back to the appliances refrig and furnace. Try to turn on the gas stove (light a burner) and get some gas rolling. Just a thought.
HODieselRam
Colorado
Posted: 11/05/09 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
I stand corrected. It could be the sail switch. This switch is normally open but if it stuck in the closed position it would give the problem I'm having. I will
check everything this week-end. Thanks again
HODieselRam
Colorado
Posted: 11/05/09 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
jimwooster
Yeah, thanks, I've had that issue before and with my hot water heater. Took a few tries to fire up.
