RV.Net Open Roads Forum: Microwave broke, do i need a special one to replace it with?
Search only in Toy Haulers
Open Roads Forum  >  Toy Haulers  >  Modifications & Accessories
 > Microwave broke, do i need a special one to replace it with?
Toy Haulers Related Tips
cleoent
San Jose
Posted: 11/02/09 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
Our WW FK1900 came with a simple GE microwave http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=JES1033WB
It broke. Lit on fire. Nice. Want to replace it. Can i just go get the same size microwave from HD and move on? Or are there special rv microwaves that might be better suited.
Polishnurse
Schodack, NY
Posted: 11/02/09 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
Any microwave that is 110 volt. But you will find it's the depth of the microwave. The ones in the RV's are generally one inches less in depth. Measure depth of the present Microwave. It the replacement is the same or you don't mind it sticking out. All will be good to go.
rgraham
Missouri
You have to find one the same size that will fit in the cabinet, it will plug in on the back side and held in with a metal clip in back and 2 screws in the front, they are much harder to get out than putting back, mine quit one time and the fuse in it had blew replaced that and was fine,that was 8 years ago,
Richard
1987 ford f250 6.9 diesel
1997 Innsbruck by Gulf Stream 28ft fifth wheel with slide
and the wife and co-pilot Trudy
Chuck&Gail
In the Colorado Mountains
Posted: 11/02/09 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
Just be careful how it is vented if built in. Most HD microwaves can't be built in. We ended up buying at Camping World to get a vented unit of the proper dimensions to fit in old cabinet space.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
cleoent
San Jose
Posted: 11/02/09 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
I took mine out already
I spotted a possible replacement, but i need to know if i need to get a special kind so it doesn't blow up with the bouncing of a rv.
DutchmenSport
Between Anderson, Pendleton, & Lapel, Indiana
Posted: 11/02/09 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
I heard in the past it is not good to use a non-RV microwave in an RV. I've never had to replace one, so have never faced that decision. However, I did find this. I thought this comment was most interesting, especially coming from a web page from Camping World:
"We contacted Panasonic, Sharp and Samsung, who all assured us that their units were suitable for use in RVs, though Sharp Electronics was the only company other than Dometic that makes a model designed specifically for RV use."
Click here to read the full article!
DutchmenSport
2005 Chevy Silverado 3500 Dually Duramax 6.6L V8 Turbo
Century Truck Cap Commercial /Toolboxes
Northeast Outfitters Canoe
2006 Keystone Springdale Model 263DBL
Weight 4985, Carrying Capacity 2575, Hitch 560, Length 30'
Width 8', Height 10' 6"
dalebear
home
Posted: 11/02/09 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
I just replaced mine it was a Magic Chef MCO2212AR it is made for RV's. The old one died a slow death. Here is the phone number 888-775-0202 not cheep it was $269 with shipping. Easy to take out and put in.
Itchey Feet
Wyoming
Posted: 11/02/09 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
We had the microwave go bad in the "C" we (had). It set in an upper cabinet and just went to the electronic store and purchased one close to the same size, built a new wooden mounting bracket and reinserted it with the old vent and was still working fine when we sold the unit a couple of years later. You could always use the space for storage and mount the new one on a counter. JMHO
My feet are fine as long as they are traveling.
cleoent
San Jose
Posted: 11/02/09 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
Would this one work? The dimensions are good, BUT it says 115v outlet.. .hmm?
http://www.walmart.com/catalog/product.do?product_id=6372382
kaydeejay
SE Michigan, USA
Posted: 11/02/09 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
So what's the problem? Your good old 110V AC is really 120V +/- 10% or 108V to 132V. All appliances will work within this range.
It's when you drop below 108V you may have problems, especially with things like A/C units.
Keith J, Retired from GM Engineering
1999 Sunnybrook 27RKFS Fiver
2005 GMC Sierra 2500HD SLE 2WD/CC/SB/DA, 52 gal Titan tank, Bilsteins, Line-X, Westin steps, Prodigy, Retrax, 16K Superglide, 5th-Airborne pin box, Multi-vex mirrors, TST TPMS.
