RV.Net Open Roads Forum: air compressor psi for blowing out lines
 > air compressor psi for blowing out lines
RJL
Manahawkin, New Jersey
Good Sam RV Club
Posted: 11/03/09 05:28am Link  |  Quote  |  Print  |  Notify Moderator
What psi do you guys set your compressor at when blowing out your lines?
Thanks,
Bob
1999 29' Georgie boy Pursuit, F-53 chasis
1998 Dodge 4X4 1500 extra cab pick up, 3" lift, 360, auto
2001 Dodge Durango
1994 Yamaha Banshee-mine
1999 Yamaha Banshee-sons
2002 Yamaha Banshee-sons
Doug and Cassi Glass
Clifton Forge, VA
Good Sam RV Club
Posted: 11/03/09 05:31am Link  |  Quote  |  Print  |  Notify Moderator
I think my manual says 35-40 psi. I don't have it handy but the pressure is low.
Bumpyroad
Virginia
IIRC some people have said 40 lbs. don't want to set it too high, volume is more important than pressure IMHO. have a faucet or two open when you crank it on.
bumpy
s & s
Michigan
Posted: 11/03/09 05:37am Link  |  Quote  |  Print  |  Notify Moderator
I set it at 40lbs.
Steve & Sally (S & S)
Houston & HiTee (Our Little Poms)
Heidi (Forever In Our Hearts and Never Forgotten)
04 NEWMAR MACA 3778 W22
05 PT Cruiser Convertible 5 speed
"Never try to outsmart your common sense"
Don36G
New Hampshire
Posted: 11/03/09 05:41am Link  |  Quote  |  Print  |  Notify Moderator
I use 40 psi, same as recommended water pressure.
jerseyjim
New Jersey
Good Sam RV Club
Posted: 11/03/09 05:44am Link  |  Quote  |  Print  |  Notify Moderator
35 for me....
RJL
Good Sam RV Club
Posted: 11/03/09 06:09am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies.
Bob
Daboo
Texas Panhandle USA
Posted: 11/03/09 06:33am Link  |  Quote  |  Print  |  Notify Moderator
my book says not greater than 30 psi--seems this works for the lines...
Hello from the windy Texas Panhandle
Winnebago Adventurer 33V
Served proudly 1957-1965..U.S. Air Force
Two Jayhawks
lenexa ks
Posted: 11/03/09 07:19am Link  |  Quote  |  Print  |  Notify Moderator
I use 40 psi and it's served me well for ten years and multiple winterizings every year. I do feel strongly that a air to water fill fitting is used. Another poster on a similar thread says he uses 100 psi and I think I'll experiment with higher pressure this weekend. I'm currently winterized (40 psi) and I would like to see if any additional pressure removes any more water.
2002 Safari Zanzibar
CAT C12 455/1550
Allison 4000
Saturn Vue w/ReadyBrake
FMCA# 390819
womps
Olds
Posted: 11/03/09 07:23am Link  |  Quote  |  Print  |  Notify Moderator
Just connect it to the same water pressure regulator you use on your coach and it will restrict the amount of air pressure the same way it does with water. You can buy the correct connections at most hardware stores.
