Ken O
I live half way between Grayling and Cadillac, MI
I picked up my new Kingsport 16' TT today. It weights 2700#.
I have an '05 Yukon with the 5.3 gas engine, and tow package.
One thing I was real disappointed was the gas mileage. When I made the trip last week to pick it out, I re-set the computer and I got 19.7 MPG. Its 138 miles each way, or 276 miles total.
Today the trip down there I got 19.4 MPG. The trip back with the TT I got 8.4 and I went 65 instead of 70MPH. Thats pretty terrible gas mileage. With my Chevy truck 350cc, I pulled my sled trailer with the sleds I got 15 MPG, and 18 without the trailer, so I was expecting to drop 6 or 7 MPG not 11.
Doesn't this seem poor mpg for such a small trailer? I get pretty good mileage otherwise I think. I checked the computer for the miles traveled and fuel used, also when I fill up I check the gallons put in on the pump with the computer, and it its always right.
dalenoel
Howell, Michigan
Good Sam RV Club
Did you drive down during the wind we had in MI last week? If so that might have some of the difference.
04 Dodge RAM Quad Crew Cab 4x4
08 Jayco Eagle 322 FKS, Hensley Arrow, Prodigy Controller
Wife and I, Oreo the Malshi, and maybe a grandkid or two
2oldman
Indio CA
It's not necessarily the weight, but the front end wind resistance.
Travelaire Canuk
Ucluelet BC , Shanghai China and who knows?
65 mph is still way too fast for economy. slow to 58 and you will see a big difference. Safer too. Bring back the 55 mph speed limit please.
RCAF(ret) Travelaire TC 215
96 Ford E350 460
98 Tracker Toad
Sterling Roadmaster Towbar
SMI Stay in Play Braking
crab80
Virginia`s Eastern Shore
On a 400+ mile trip I got 10.5 mpg towing a 30 footer, avg 60 mph. I get 19 to 20 empty with a Silverado 5.3l. I had minimal gear in the TT as I was bringing it home from dealer so I will do a little worse on mpg with it loaded.
2010 Jayco 28BHS
2004 Chevy 1500 Ext.Cab 5.3L, 3.73, Bilsteins
Reese Dual Cam
Prodigy P3
Barker 3000 jack, 22 Blue tote
johnrbd
Hanford CA
Remember, ST tires are rated only to 65 mph.
kknowlton
Wisconsin Border Country, IL
8.4 sounds pretty normal to me for a full-height trailer driving 65 mph. We get about 9-12 mpg (depending on terrain and headwind strength) driving 55-60 mph towing, about 19 solo on the highway (similar terrain). If you want better mileage, slow down, but don't expect what you got with your lower-profile sled trailer.
tatest
Oklahoma
How much power you need to push air around depends on frontal area of trailer and the cube of air speed. Your sled trailer probably doesn't increase the frontal area much, the TT likely doubles it or more.
For a first estimate, you should expect cruise mpg pulling a TT to be about half of what it is pulling nothing, on level ground and no wind. Full size drop-in campers have the same effect.
Tom Test
Itasca Spirit 29B
2001 Ranger Edge
shum02
Burlington ON CDA
It's not the weight or even the length it's the sail your pulling into the wind. Welcome to the club.
I average about 19mpg on the highway doing 55- 60mph/90kph and about 9 - 12mpg depending on the terrain/wind towing 7000lbs. Outside of a diesel this is just about as good as it gets pulling a TT with a gasser.
Read through all the forums that all your going to see, there is no magic bullet to get anything better that won't cost a fortune for a marginal gain.
2007 F150 XLT CC 4x4 5.4L 3.73LS
2007 KZ2505QSS-F Outdoorsman
Camping Pic's and Mods
Winter Camping Tips and Tricks
tafische
Memphis
Where you using cruise? I just starting towing a heavier TT. Mine has been better with cruise off. When it is on, going up a hill - it downshift and really rev the engine high to stay at speed. The little speed and time I loose going up hills is worth it for the gas I save.
