RV.Net Open Roads Forum: Class A Motorhomes: Sealing Areas on Roof
 > Sealing Areas on Roof
USMC46
Montana
Good Sam RV Club
Posted: 11/04/09 06:54am Link  |  Quote  |  Print  |  Notify Moderator
I was on my coach roof again yesterday and was reminded of the gradual deterioration of the various "sealants" around the various protrusions including antennas, skylights, etc. Some are "sealed" with a very thick, black product that has cracked badly. Is there an easy way to reinforce all these factory done sealing jobs, or is it a case of every few years taking all the sealants off everything and resealing ? If so, what is the preferred product ? Can you seal over the cracks in this factory sealant with something soft enough but lasting that will fill all the small cracks ? Coach is a 2004 Dutch Star.
Jim & Carmel
http://sayreodyssey.blogspot.com/
2004 Dutch Star 41'
2006 Jeep Liberty
Blue Ox Aventa Tow Bar
Brake Buddy
jtel
New Mexico
Posted: 11/04/09 07:25am Link  |  Quote  |  Print  |  Notify Moderator
The sealant will deteriorate, and the best way to repair is to do it right...take a putty knife, and remove old cracked sealant. Replace with Dicor sealant...available at Camping World, or most RV dealerships. Make sure to only use Dicor or an equivalant product that is made to adhere on a rubber roof. Never use silicon. A little elbow grease and time is the best fix. When you're done...don't forget to clean and apply UV protectant to the rubber roof. Then you're good to go!
2006 Sportscoach Encore
Sailbad
Oklahoma City
Posted: 11/04/09 07:34am Link  |  Quote  |  Print  |  Notify Moderator
The Dicor will work....but there is a better fix. Run a search on eternabond...
Dave C.
2005 Silverado 2500 CC
Duramax 6.6 3.73 V-2
2003 Wildcat 27RL
B&W with Companion
Prodigy
trop-a-cal
Palm Coast Fl
Posted: 11/04/09 07:44am Link  |  Quote  |  Print  |  Notify Moderator
It's called flowing caulk, that goes right into the cracked caulk and runs down to fill any voids before it sets up. The vibrations from the roads cause the caulks to crack, and the sun makes them ooze. It's a every 6 month job to be done prior to cleaning the roof when it is dry. Then let it set up before washing. Some flanges have to be repaired by pushing in the old caulk or replacing it, but most just need the cracks filled.
John339
Clyde Ca. USA
Posted: 11/04/09 08:00am Link  |  Quote  |  Print  |  Notify Moderator
I have used Eternabond and it lasts and lasts.
It is a tape available in different widths and lengths and white or grey.
Very sticky and stays flexible.
Search the posts for Eternabond.
John and Cindy and Misty Rain and Senor Paco(Chihuahuas)
1994 Coachmen Catalina 300 MB RD
in sunny Clyde, Calif. KE6IDM
Economical Handyman
S. California
Good Sam RV Club
Plans on which roof you have on your DS. ?
DeWayne & Judy
04 3810 Dutch Star
ISL 370 9.3 mpg
Frank's autoformer
01 Sahara Jeep-toad
Blue Ox Aventa II
F 374382
This is not the "GOLDEN-YEARS", it is the "RUSTY-YEARS" !
Doug and Cassi Glass
Clifton Forge, VA
Good Sam RV Club
Posted: 11/04/09 11:41am Link  |  Quote  |  Print  |  Notify Moderator
I 3rd Eternabond. I cleaned my old sealant off first but according to Eternabond it can go right over the old sealant.
