RV.Net Open Roads Forum: Levels on Gauges Still Reading 1/2 Full
 > Levels on Gauges Still Reading 1/2 Full
ArchHoagland
Clovis, CA, USA
Good Sam RV Club
Posted: 11/04/09 11:36pm Link  |  Quote  |  Print  |  Notify Moderator
I fill my black/grey tanks with water and Dawn, Fabric softner or dish washer soap. I then let it sit for a couple days and then drain it.
It clears up the sensors for a while but then it's back to the same old problem.
I pretty much just look down inside the toilet to see what the level is.
After all, what do you expect for $125,000? Something that works?
2004 Monaco
La Palma 36DBD
Two Slides
2 Potties
Workhorse 22 chassis
8.1 gas engine & Allison 1000 transmission
7.1 MPG based on fuel used over 32,000 miles
TOADS
US Gear Brakes
1991 Mazda Miata 5 speed 33MPG 2,310 LBS
Yaj
The Milky Way Galaxy (Hartford, WI)
Posted: 11/04/09 11:50pm Link  |  Quote  |  Print  |  Notify Moderator
The old is the glass half full or half empty? In this case being the pessimists I opt for the "totally empty" and the gage is not working!
1996 HR Endeavor LE,Cummins 5.9 230hp, Allison 3060,
Front-Yamaha Enduro, Rear-Honda Helix Geeser Cruiser + 2 bikes,
22ft 1977 Cruiser in tow.
1 DW, 2 kids.
2 dogs, 2 cats.
I wasn't thinking this far ahead!
Dirtman
South Dakota Fulltimer
Good Sam RV Club
Posted: 11/05/09 04:45am Link  |  Quote  |  Print  |  Notify Moderator
After seven years of fulltiming, I find the best cure is NEVER dump less than half a tank of black water. Add fresh water to the black tank if necessary.
While I prep the rig to drain tanks, the bride is busy filling the toilet with fresh water. The instant I have the black water drained, she drains the toilet, and five gallons of water splashes through the three inch hole, and splashes the sides of the black tank, removing any residue. If necessary, we'll dump a second potty full. Then I close the black valve, and she dumps another full potty into the black tank, adding Aqua-Chem, or a cup of vinegar. Our tanks have always worked flawless once we started using that procedure.
Grey water has never been a problem, since that valve is usually open in CG's with full hookups, and there's usually always soap in the tank when rough camping anyway.
Dirtman
2003 Newmar "D"Star 4050
Freightliner(Neway IFS) 330HP Cat
22'Haulmark V nose hauler
2004 Chev Silverado Z-71, 4X4 toad
BrakeBuddy
WadenCeeJay
Spring, Texas
Posted: 11/05/09 08:03am Link  |  Quote  |  Print  |  Notify Moderator
Good to know I am not the only one with sensor issues.
* This post was edited 11/07/09 10:39am by an administrator/moderator *
vfrmarc
Ohio
Posted: 11/05/09 08:19am Link  |  Quote  |  Print  |  Notify Moderator
Winterized about four weeks ago and at first sensors registered above empty. Now that everything is sitting for awhile the sensors all read empty. Seems to always work that way.... Like was said earlier the sensors were wet and now they are dry.
SRT
Head of the Lakes, MN
Posted: 11/05/09 08:22am Link  |  Quote  |  Print  |  Notify Moderator
Use Dawn non-bacterial dish soap and Calgon in the black water tank. After dumping, put this stuff in with about 5 gallons of water. As you are driving the sides of the tank get cleaned off. Keeps that sensor usually working. The grey and fresh water sensors have always worked good.
SRT
2000 32' HR Vacationer with Banks
1998 Subaru Outback Ltd. 5 spd
Brake Buddy & Blue Ox Aventa II tow bar
FMCA #266040 HRRVC #84109
kraemer20
CT
Posted: 11/05/09 09:05am Link  |  Quote  |  Print  |  Notify Moderator
Thank You All. As usual a lot of good input.
Waco Kid
Honey Brook Pa.
Good Sam RV Club
Posted: 11/05/09 09:09am Link  |  Quote  |  Print  |  Notify Moderator
I installed (these) and so far so good, there easy to install but the tanks are hard to get to....Bruce
  • Bruce & Sandy
  • 07 Scepter 42PDQ
  • 1 Golden Retreiver
