My 1993 Dodge high top van looks like it needs to be recaulked where the fiberglass meets the metal van roof gutter. What is the recommended caulk to use?
Also, I see a fine stress crack in the front of the high top about eight inches running center from top to bottom. No leaking problems from it. Will this be a problem later?
Ron
RonAllen wrote: My 1993 Dodge high top van looks like it needs to be recaulked where the fiberglass meets the metal van roof gutter. What is the recommended caulk to use?
Ron
The best is Pro-Flex RV . It worked GREAT for my leaky Class B hightop. It adheres to the metal , fiberglass and aluminum . it wont peel or crack apart when you hit the road . This stuff works . I was told by my local RV shop to use silicone , DONT DO IT !!!
CHAIN
