RV.Net Open Roads Forum: Hybrid Travel Trailers: Just a assurance question.......................
Open Roads Forum  >  Hybrid Travel Trailers
 > Just a assurance question.......................
Hybrid Travel Trailers Related Tips
Valkdryver
South Dakota
Posted: 11/05/09 08:42am Link  |  Quote  |  Print  |  Notify Moderator
We have a 2009 Dodge Ram 1500 Laramie with the 5.7 Hemi, just bought a 2010 Shamrock 23SS, should not be a problem towing............right? I know that this is a "after the fact" question, but my mind told me that everything would be fine. We will also have the Equalizer WDH and a Prodigy brake controller.
I will also set the camper up to pull doubles, I pull my 16' aluminum boat behind the camper, this is legal in South Dakota up to 75' total length. It hase a Reese swaybar between the camper and the boat. The boat and trailer weigh around 1000 pounds.
Last year I pulled the same boat behind the same pickup, but the camper was a Kodiak 195.
Thanks, Arlo
bikendan
Napa, Cal.
Good Sam RV Club
Posted: 11/05/09 09:41am Link  |  Quote  |  Print  |  Notify Moderator
i will say that you'll have no problem with pulling the 23SS with your truck. we have a Avalanche with the 5.3 v-8 and it's fine.
but as to double towing, i can't help you there. i know that the 23SS is a lightweight TT/frame and putting a receiver on the back to pull a boat, may void the warranty if something happens.
some manufacturers say welding a receiver to the frame for a bike rack, will void the warranty, let alone tow a boat with it.
Dan- Firefighter, Shawn- Musician/Entrepreneur, Zoe- Faithful Golden Retriever, 2007 Chevrolet Avalanche LS, 2007 Rockwood Roo 23SS w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
llowllms
Crawford, Tn. USA
Posted: 11/05/09 09:55am Link  |  Quote  |  Print  |  Notify Moderator
I had a Dodge 5.9 liter engine and it pulled our ROO 236 rather well. The problem was with the transmission. After three years it went out. That seems to be a weak point with them. I can't talk about the 2500 and 3500 series, no experience there.
skipnchar
Topeka Kansas USA
Posted: 11/05/09 11:01am Link  |  Quote  |  Print  |  Notify Moderator
Certainly no problem with the TRUCK with that towing set up but it's POSSIBLE you could have a problem with the TRAILER if you need to have warranty work done. with MOST small trailers the manufacturer will not allow towing double though the weight in your case is probably not enough to cause much of a problem it WOULD give them an "out" for warranty claims. Good luck / skip
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
Chuck_S
Broadview Hts, OH, USA
Posted: 11/05/09 01:36pm Link  |  Quote  |  Print  |  Notify Moderator
Neither "Laramie" nor "Hemi" are much use in checking your maximum towing capacity. It's not determined by the upholstery, but by the size of the engine, the transmission, and chassis.
How many doors? Regular cab, crew cab, quad cab?
Short bed, long bed?
4x2, 4x4?
3.55 or 3.92 axle?
4.7 or 5.7 V8?
But you can check it yourself at Trailer Boats (not Trailer Life).
-- Chuck
'06 Roo 23SS behind '07 Expedition out of Cleveland
Our Photo pages
