RV.Net Open Roads Forum: Class C Motorhomes: weep holes
 > weep holes
Class C Motorhomes Related Tips
stormin' norman
Lansdale, PA
Posted: 11/05/09 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
I HAVE A 31 FT MINNE WINNIE AND I AM CURRENTLY TRYING TO FIND WATER LEAKS IN THE OVERHANG COMPARTMENT. On the roof between the main roof and the overhang is a casing covering the joint running the full width of the rv,protruding from the casing are two three inch square and flat pcs. with the words " Weep Hole". Has anyone seen this before ? I am thinking about caulking the opening.
CloudDriver
New Jersey Shore
Good Sam RV Club
Posted: 11/05/09 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
It would be helpful if you could post a picture.
2003 Winnebago Minnie 24F - Ford E-450
dicknellen
Northern Nevada, USA
Posted: 11/05/09 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
What year and model number, is it a Minnie or a true Minnie Winnie?
murffdog
Poughkeepsie, NY
Posted: 11/06/09 06:07am Link  |  Quote  |  Print  |  Notify Moderator
A "weep hole" is mean't for water to "weep" out such as condensation. All the windows should have "weep holes" on the bottom.
stormin' norman
Lansdale, PA
Posted: 11/06/09 08:16am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2000 model #331c winnebago minnie with a slide out,ford
e-450.the weep holes are on top of the out side roof.
dicknellen
Posted: 11/06/09 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry can't help my 2004 329B Minnie with two slide outs has no weep holes. Like CloudDriver said can you post a picture.
stormin' norman
Lansdale, PA
Posted: 11/06/09 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
thanks for the input,it seems like the leaks are from the upper outer edge of
the overhang."I hope".
CloudDriver
New Jersey Shore
Good Sam RV Club
Posted: 11/06/09 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
I found a leak in the cabover on the passenger side a couple of years ago. It turned out that the water was getting in at the joint between the sidewall and the floor. The trim strip that is supposed to cover and seal this joint only overlapped the sidewall by about 1/16th of an inch and did not achieve a seal. By pushing in on the sidewall, I was able to see a gap. I added the sloppy looking bead of Dicor in the picture below and there has been no sign of water since.
Dakzuki
Carnation, Wa, USA
Posted: 11/06/09 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
I found that one of my big side windows has weep holes on the top and bottom. It looks as if it is designed to one can use it on either side of an RV. The problem is some weep hole covers popped off on the "upper" holes. The other day it was raining hard and I was parked with the RV tilted just right. A torrent of water was running right ovee a hole at the top of the window and was coming into the RV from the window frame. I have since taped over the upper holes and will be plugging them when it gets warmer out.
95 Chinook Premier
 > weep holes
