RV.Net Open Roads Forum: Class A Motorhomes: solar panel for class A coach
 > solar panel for class A coach
Sully2
Cincinnati
Good Sam RV Club
Posted: 11/06/09 07:42am Link  |  Quote  |  Print  |  Notify Moderator
dav5942 wrote:
And for the money ($850) hard to beat the Honda EU2000i. Just spent over 100 days dry camping this year burning less than a gallon every 4 days for $75 cost of fuel. The Honda maintains our 4 house batteries which we use for TVs, coffee pot, etc. No hastle setting up and quiet. Used the big jenny maybe 5 times.
Dave: Do you charge directly off the genset itself...OR...do you run a separate battery charger plugged into the genset??
2000 Country Coach Allure; Cummins ISC 330 HP; 71/2 - 8 MPG regardless
2002 Jeep Liberty
Mike and Mona
Washington state, home
Posted: 11/06/09 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you all for your information, I have gotten some good ideas from them. The pictures were super, I see lots of getting up on the roof to raise and lower the panels, not much in favor of that but guess it is the only way, short of motorized panels huh?
RicJones
So. Cal.
Posted: 11/06/09 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
You don't really HAVE to tilt the panels but they work better. If you don't want to deal with the tilt, then you might want to go with a little extra wattage to make for it.
dav5942
Stuart, FL
Posted: 11/06/09 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, thru the shore cable. We set the Inverter/Charger to10amps and use the remaining 10amps for tvs, etc.
2007 Newmar 42' Mid Engine w/Fatboy,ATVs-in Garage,Rubicon w/4" lift,MotorMetal whls,MickeyT Baja tires-Cherokee w/4"lift in tow, Hog Valley FL(a diamond in the rough)
Alaska '09 Part2
Alaska Fishing Newmar Mid Engine '09 On the Road Again
Sully2
Cincinnati
Good Sam RV Club
Posted: 11/06/09 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
Gotcha!..thanks
* This post was edited 11/06/09 08:38pm by Sully2 *
jauguston
Bellingham, WA
Posted: 11/06/09 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
I like the Honda EU 1000i over the 2000 because all I want it to do is charge batteries (4-6v w/2500w inverter). It will power a 45a converter and is only 29 pounds and small. If we want to use the microwave we fire up the noisy Onan 6500.
Jim
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 275
AIMS 2500w inverter 4-6v GC batteries
4-Kyocera 130w solar panels SB3024iL MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
klenger
Tucson AZ
Posted: 11/06/09 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
Here's my setup. 520 watts. Works great, but I need more battery storage.
http://www.flickr.com/photos/klenger/sets/72157608408114353/
2008 Tiffin Allegro 32BA FRED Class A Motor Home
2008 Honda CRV, Blue Ox, SMI DUO Stay-in-Play Brake
