RV.Net Open Roads Forum: Class A Motorhomes: Norcold Refrigerator LED Panel is Flashing
 > Norcold Refrigerator LED Panel is Flashing
Fox & Bear
Ontario, Canada
Posted: 11/05/09 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
Symptom - All LED's are flash,pause,flash,pause.
The owner's manuel says to call for service. Does anyone have a self fix for this problem? My DW is insisting that I ask this question.
Fuse has been changed.
Barb & Bob
dodgebob08
Mississippi
Posted: 11/05/09 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
i think all the LEDs on mine flash if the battery is down, not enough juice to run the refridgerator. even plugged in, mine won't run without a charged battery. my battery went bad once and this happened and my convertor went out once and the same thing. lights (12 volt) would still work but not very bright.
2008 Dodge 2500 MegaCab CTD
2006 Copper Canyon 295RLS
Don Parrish
AZ
Posted: 11/05/09 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
Gee, Bob,
Make this easy...call Norcold. I've called them...they don't bite. Sometimes the answer there is the short fix and no expense. But you won't like the "phone tree", but hang in there...the toilet guy can't help you.
George H
Washington
Posted: 11/05/09 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
Had this last trip out, disconnected both 110 and 12v power for a few minutes, reconnect power and no more problem (on a PC it'd be called a reboot).
George, Juanita and Mandie (boss Shar-Pei)
01 F350, PSD, DRW
05 Carri-Lite 32RS3
sehunter
Rancho Murieta, Ca.
Posted: 11/05/09 10:45pm Link  |  Quote  |  Print  |  Notify Moderator
Bob,
Call Norcold they are really good people they just replaced my cooling unit and I am in my third year of ownership.
Stan
2008 Bounder
38P, W24, 8.1L, 3 Slides
05 Ford Ranger Edge 5 spd
ChrisNorcold
Ohio
Posted: 11/06/09 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
All LED's Flashing you must have a model 9182 or 9162 Norcold refrigerator. That flashing usually means you have a bad power board (Rear Board) Knock on the power board cover. This may free a stuck relay. If that does not work disconnect the 12VDC for 10 Seconds if the problem returns you will need to have the Power board changed. Good Luck Chris
