RV.Net Open Roads Forum: Fifth-Wheels: Attic ventilation system
 > Attic ventilation system
Fifth-Wheels Related Tips
greg0rn
Republic of Vancouver Island
Good Sam RV Club
Posted: 11/05/09 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
Is anyone familiar with attic ventilation system? How critical it is to have one in a 5th wheel having wooden trusses in its roof?
Thank you for all replies.
Greg, Shirley, Misha (the dog)
2006 1 ton Dodge with CTD, SRW, extended cab, 4x2, short box, 3.73 LSD, J-brake, Superglide hitch, Prodigy controller, Line-x, Pressure-Pro.
2004 Citation Supreme 26RKS 5th wheel
mwebber78
Maine
Posted: 11/05/09 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
Some of the higher end units have it and they sell it as critical on units that will see full-time or extended stay use. Makes perfect sense to me given the critical nature of ventilating your house attic, most contractor's follow a strict formula of square footage to total ventilation area.
If you plan on using a rig for frequent extended use you may want to consider a coach equipped with this feature.
Michael
2 DD's and my DW
6 Acre's in Southern Maine
2009 Crossroads Cruiser CF31SB
2008 Chevy 2500HD LT 4X4
Camping Pictures
greg0rn
Good Sam RV Club
Posted: 11/05/09 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
Actually, my Citation Supreme 5th wheel has it installed. I'm just curious about what happens over there, in the attic. Most of us will never see the innards after a few years of being exposed to the elements.
I hope that someone with some practical experience dealing with roofs and so on will respond.
mwebber78
Maine
Posted: 11/05/09 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
I would think it would work no different then your house. In extreme weather changes or humidity I have been up there and the vents move/circulate air. Do you have a specific concern like mold?
charlan
On. ca
Posted: 11/06/09 05:57am Link  |  Quote  |  Print  |  Notify Moderator
I would think that vents are nessasary whether it's wood or aluminiom, mine has attic vents and I have aluminium trusses.
2008 LMM GMC 3500 SLT 4X4 HD LB Duramax 6.6 Turbo Diesel Dually
Hijacker 4 Way Pivot, Integrated controler,
2004 Prowler Regal Advantage AX6 36.5 FLTS
Jim-Linda
Livingston, TX
Posted: 11/06/09 07:47am Link  |  Quote  |  Print  |  Notify Moderator
Does your S&B have an attic that is exposed to the elements? Neither does your trailer.
Jim
greg0rn
Good Sam RV Club
Posted: 11/06/09 09:46am Link  |  Quote  |  Print  |  Notify Moderator
mwebber78 wrote:
.....Do you have a specific concern like mold?
Perhaps, or worse, like rotting trusses and plywood. It is a dead space there without air circulation.
woodburner
Mentor Ohio
Posted: 11/06/09 10:09am Link  |  Quote  |  Print  |  Notify Moderator
Personally: the so called attic ventilation system offered on most coaches must be magic because there needs to be airflow to have ventilation and if they insulate these things to the R-values they publish it does not leave any room for airflow! Sounds like a lot of baloney to me. JMHO
Everest Owners Club...Join us!
Jim-Linda
Livingston, TX
Posted: 11/06/09 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
There must be different "method's" for attic construction. We have a '98 Champagne 38', with the "attic". There are 5 vents on the roof to ventilate the space. No magic.
Jim
woodburner
Mentor Ohio
Posted: 11/06/09 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
Exactly the point; there is no space!
