RV.Net Open Roads Forum: Folding Trailers: 99 Starcraft Meteorite
 > 99 Starcraft Meteorite
Folding Trailers Related Tips
YNPMeteorite
Yosemite National Park
Posted: 11/05/09 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
I just bought a used Starcraft trailer..just wondering how the support poles are supposed to be mounted? If anyone has a picture or diagram I would appreciate it.
oakmandan
Cedar Rapids, Iowa
Posted: 11/06/09 09:23am Link  |  Quote  |  Print  |  Notify Moderator
Are you talking about the support poles for the bunk ends?
Dan and Janelle
Lily and Sherman the smelly Bassets
2005 Ford Escape XLT, AWD, V-6
1994 Skamper 22C Plan D
Nights camped in 2008 .... 16
Nights camped in 2009 .... 26
YNPMeteorite
Posted: 11/06/09 10:19am Link  |  Quote  |  Print  |  Notify Moderator
Yes, I feel bad because I watched the guy when I bought it. Of course thats been a week ago. So yes the supports under the bunks. Thanks
oakmandan
Cedar Rapids, Iowa
Posted: 11/06/09 11:36am Link  |  Quote  |  Print  |  Notify Moderator
The support poles should be permanently mounted under the beds. Pull the bed out, have someone hold it up while you look under it. It should have a clip of some sort holding one end in place. Pull the pole out of the clip and look on frame for a place the pole hooks or slides into.
Hope this helps.....
Dan
YNPMeteorite
Posted: 11/06/09 11:39am Link  |  Quote  |  Print  |  Notify Moderator
I have the support poles. One looks like a small roll bar off a truck to discribe it. I see the slots in the frame and such. I figure it should be a easy process I just am not seeing how right now. Anybody have this piticular trailer? Thanks Roy
oakmandan
Cedar Rapids, Iowa
Posted: 11/06/09 11:42am Link  |  Quote  |  Print  |  Notify Moderator
Ok, didn't realize they were not mounted to bottom of bed. Good luck!
'tiredTeacher
Richmond, VA
Posted: 11/07/09 06:01am Link  |  Quote  |  Print  |  Notify Moderator
If your Starcraft is similar to mine, your "roll bar" should have tabs at the ends. They fit into slots on the inside of the box edge. The hinged poles fit into the innermost holes on the side of the tongue. This is attached before the bed is slid out.
The other end probably has two poles with a hinged pole on each. Tabs in slots, same as front, hinged poles fit into slots on trailer frame, each side of spare tire.
Wright and Penny
Tundra 4X4
Starcraft 2107
"Remember to keep it simple. You can't get away from it all if you take it all with you."
http://www.webshots.com/user/awellis3
StreetRodderTom
South Western CT.
Good Sam RV Club
Posted: 11/07/09 07:42am Link  |  Quote  |  Print  |  Notify Moderator
If you can post some jpegs of what you have it would be of help.
Hope to see you on the road!!!
Soon to be retired Gunsmith (35+ years)
Wife is retired RN (VA Hospital 37 years)
2005 Starcraft Model 2409
YNPMeteorite
Posted: 11/07/09 08:14am Link  |  Quote  |  Print  |  Notify Moderator
IF there is a way to post clear pics I would greatly appreciate it. Yes I have all of those support bars! Couple more questions, how do I operate the heater and fridge. I know...should have had these things shown to me, just was to excited to be getting a pop up. Thanks to all that have responded Roy
red31
Bryan
Posted: 11/07/09 08:20am Link  |  Quote  |  Print  |  Notify Moderator
Try this 2004 manual for help, page 15
manual
