RV.Net Open Roads Forum: Tech Issues: Electronic parts
 > Electronic parts
Tech Issues Related Tips
Rockiesview
Western Colo.
Posted: 11/06/09 12:06am Link  |  Quote  |  Print  |  Notify Moderator
Does any one know where I can look for discrete electronic components?
I will be tearing into the 7355 converter I pulled out of friends trlr a few weeks ago. I would imagine that it is impossible to get a schematic of it now days.
This unit is pop riveted, so will have to drill out rivets and be careful with metal filings. Usually Mfg. Co. call this pre-priorty information so will not give out any info. If I can find #'s on components I could repair this fairly easy I believe, so that is the reason for the original question.
I used use Mouser Electronics, assume they are still in busines, any others?
Thanks, Bob
tomlang
Los Angeles area
Good Sam RV Club
Posted: 11/06/09 12:39am Link  |  Quote  |  Print  |  Notify Moderator
Digi Key is also good. They have no minimum order and carry almost everything.
In my opinion, you would be better off the to replace the entire converter/charger section with a new three-stage charger. The original is not worth repairing.
Drop-in replacements are available, or you can do as I was planning to do, and buy a charger that fits in the space under the original converter. I bought a 45 Amp Iota and never got around to wiring it in (sold the RV instead). The 7355 is a single-stage charger that charges too slowly when the batteries are low and need a fast charge, and charges too rapidly (boiling the batteries dry) when they are fully charged and need only a gentle float charge.
By the way, I have two of the 45 Amp Iota chargers that I am planning to sell on eBay when I get around to it. I bought them on eBay a year ago for around $125 each.
Tom and Lynne
Tom is an Electronics Engineer, Lynne a retired teacher.
2003 Foretravel 38' U295
pulsar
Lewisville, NC
Good Sam RV Club
Posted: 11/06/09 07:19am Link  |  Quote  |  Print  |  Notify Moderator
Moved from Technology Corner to Tech Issues.
Chris Bryant
DeLand, Florida, USA
Posted: 11/06/09 08:05am Link  |  Quote  |  Print  |  Notify Moderator
I use Digi Key as well.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
Rockiesview
Western Colo.
Posted: 11/06/09 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
We have already replaced the 7355 with a new replacement unit, forget the name (friend did the ordering), so this is more or less a hobby thing and will be a backup spare for several of us, if it can repaired cheap enough
DoubleClutcher
Ridgcrest,CA
Posted: 11/06/09 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
I use Digikey and Mouser for most of my stuff. Another source for odd ball items is Jameco. They handle standard components as well as surplus buys.
An example is a 50 amp current shunt I bought several years ago at Jameco. Put it in series with the battery bank, run a pair of small diameter leads into the RV, hook a DVM across it, and it reads 1mv/amp. I use it when dry camped and charging the battery on the generator to see when the current has dropped off to a few amps.
I don't see it in the catalog now, but http://www.rc-electronics-usa.com has a 10A version.
Sorry I got carried away.
motormouth2644
Pensacola Fl
Posted: 11/07/09 05:10am Link  |  Quote  |  Print  |  Notify Moderator
Hello
PPL is a good one also
bigfootford
Fair Oaks, California
Posted: 11/07/09 09:55am Link  |  Quote  |  Print  |  Notify Moderator
I use Allelectronics for most stuff. Digikey for things Allelectronics doesn't have.
They have shunts....
meters and shunts
They have relays, meters, all kinds of electroinc toys.
Jimbo
94 F-250 ex cab,460, E40D tranny,airbags w/pump,bilstein shocks, 2000 Bigfoot 9.6 2500 camper, Progressive Dynamics 9260, Trimetric monitor and an eu2000i honda genny.
Wife and Molly- Ausie,Queensland healer
Wherever I happen to park
Posted: 11/07/09 10:26am Link  |  Quote  |  Print  |  Notify Moderator
In many cities you will find an electronics parts store..
Now> Find a "Joe's Television repair" (Generic name) and ask Joe (Again generic name) where he shops for parts.
Some parts (not many today) you can get at "The Shack" some you can get at Fry's but places like RS-Electronics or _____ electronics (Again generic name, RS is an actual dealer) are the best parts source
And some times even they don't have it
I've spent hours on the web on occasion.
DoubleClutcher
Ridgcrest,CA
Posted: 11/07/09 10:54am Link  |  Quote  |  Print  |  Notify Moderator
I haven't seen a Joes Television Repair in decades. The usual repair procedure is Waste Management followed by one of the discount dealers.
By the way I was a Hoffman factory TV repair type in the early 50's in the Los Angeles area. Carried a trunk full of vacuum tubes.
 > Electronic parts
