RV.Net Open Roads Forum: Toy Haulers: Why aren't my brake lights working?
Search only in Toy Haulers
 > Why aren't my brake lights working?
Toy Haulers Related Tips
<3myRebel
San Diego
Posted: 11/06/09 10:21am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2007 Carson Rebel Toy Hauler and it is towed behind a 2002 Tacoma. All the lights work on it except for the brake lights. Turn signals and the brake lights on the truck work just not on the trailer. Has anyone else had this problem and know how to fix it?
carringb
Corvallis, OR
Posted: 11/06/09 10:32am Link  |  Quote  |  Print  |  Notify Moderator
Your tacoma has converter to combine the brake and turn signals into combined circuits for the trailer. Usually they are mounted in the rear bumper. First step to diagnose would be to test the brake wire going into the converter, and see if it is getting 12v when brakes are applied.
If yes, converter is probably. Most likely, it is not getting anything, which will require some old fashion connection troubleshooting to see where the connection is broken. If the brake and turn signal wires into the converter are connected to the truck's taillights with slice connectors, that splice connector is most likely the problem.
Bryan
2000 Ford E350 DRW Wagon (14-pass all captains chairs)
V10 w/ Banks PowerPack, Diablo Predator, 4.56 LS, 250,000+ miles
Had: Weekend Warrior 41' FSW
midnightsadie
ohio
Posted: 11/06/09 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
if they did work,and quit?? check the ground ,most light problems that apear over night come back to a ground.
timdog
mesa, arizona
Posted: 11/06/09 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
my titan has a fuse just for all trailer lights ie, seprate fuse for trailer brakes and left turn and right turn etc. check them first.. good luck
DavidM49
Bartonville, IL
Posted: 11/09/09 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
I had this problem with my Raptor, and it was actually an issue with my truck. There may be a separate towing brake light fuse and it will blow before the main brake light fuse. Check to see if you have power to your plug and if not, check your owners manual on your truck to see if you have another set of fuses just for towing. I had a 25A one blown for some reason. My RV service shop gave me that heads up and I very much appreciated it. Good luck.
Big Dave
2008 F350 Superduty 6.4 TD "Bumbles"
2007 Keystone Raptor 3814
2004 Polaris Sportsman 700 EFI
2008 Yamaha Raptor 250 SE
2007 Yamaha YZ85
2006 KX65
2006 Polaris TB250
Assorted other toys
2 Boys who only know one speed
