RV.Net Open Roads Forum: Technology Corner: Long Range WiFi Repeater for RV's
 > Long Range WiFi Repeater for RV's
Technology Corner Related Tips
flibmeister
Gold Canyon, Arizona
Posted: 11/06/09 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
Anybody using this?
creeper
Richmond Hill, Georgia
Posted: 11/06/09 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
i'm using a repeater without the antenna... Their own firmware i believe is an altered version of DD wrt..
I got the linksys router with installed DD WRT off of ebay for $25... You can get a brand new buffalo router for about $60..
Travel Blog
YC 1
Yuba City Calif.
Posted: 11/06/09 09:48pm Link  |  Quote  |  Print  |  Notify Moderator
I am. I am a techno geek as well. Not all that great in operation. I have used it successfully and lit up my MH area but it can be frustrating to use if not impossible sometimes. I prefer the super wi fi antenna system for ease of use and performance. I will try to find and include the link.
super wi fi antenna
H/R Endeavor 2008
2007 Hummer H3 toad
Ranger Boat
stevelv
Living on the island
Posted: 11/06/09 11:06pm Link  |  Quote  |  Print  |  Notify Moderator
Save your money.
A Linksys WRT54GL or a WRT54G-TM can be found for around $45 and the firmware is free of charge from www.dd-wrt.com
It's pointless using it with a onmi directional antenna - get some sort of directional so you can point it to get the best signal strength - I love the Cantenna for it's performance but there are many out there to choose from - any of them is better than an omni.
For about $90 you can your own system and as you will be doing the small amount of work yourself it will help you understand what's going on and how to get the best out of your WiFi.
RV Park Finder
Ex Fulltimers
Repairing/Restoring 1984 Monaco Regent 36' Gas to restart RVing
DH,DW,Jake and Indie
jcpainter
Crossville, TN
Posted: 11/07/09 04:06am Link  |  Quote  |  Print  |  Notify Moderator
Hey Alex (from th 3gstore)
Is there a "wifi booster" solution yet that will utilize the Cradlepoint MBR1000?
Your knowledge and input is respected.
EVDOalex
Dallas, TX
Posted: 11/07/09 06:56am Link  |  Quote  |  Print  |  Notify Moderator
thanks very much for the flattery!
staff has spent over nine months reviewing many different wifi bridge options
our wifi bridge solution should be written up and announced in about two weeks.
it ships with 5 dBi high gain omni antenna, and a 15 dBi directional antenna is optional.
its a brand new model from an established manufacturer, and we'll have it first.
FYI, our most important criteria for selecting a wifi bridge was the ease with which we can support it for the RV community.
http://blog.rv.net/about/alex-sian/
Kamphiker
South Florida (this 'aint paradise anymore)
Posted: 11/07/09 07:26am Link  |  Quote  |  Print  |  Notify Moderator
I'm using a homemade version of the above it works so well. I'm a HUGE fan of DD-WRT firmware.
Linksys WRT54GS V4 router
Flashed firmware with DD-WRT v24-sp2 (10/10/09) mini
(SVN revision 13064)
Set as a Universal Wireless repeater
Then to repeat any open network added the script AutoAp-DD-WRT using Jffs to call up the script
The antenna can be bought or built. I use Home=Brew 6dbi Collinear Antenna
This is a good write up on doing basically the same in a RV application
And for killer performance The WiFi Predator
2006 Winnebago Outlook WF324V
2009 Honda CR-V 2wd TOAD ......Campgrounds in the Smoky Mountains NP
Last Camping trip ->Elkmont Summer 2009 slide show
NEW-> Memories of OLD Miami, Fla. (pictures)
jauguston
Bellingham, WA
Posted: 11/07/09 09:29am Link  |  Quote  |  Print  |  Notify Moderator
I have that same Hyperlink 14.5 db directional antenna connected to a Alpha AWUS 036H USB adapter. We use Satellite TV so I cut the batwing off of its mount and mounted the Hyperlink antenna onto it with a mount I built having a R/C model radio servo to control vertical tilt. Works great.
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 275
AIMS 2500w inverter 4-6v GC batteries
4-Kyocera 130w solar panels SB3024iL MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
frank-2
Ontario
Posted: 11/07/09 11:43am Link  |  Quote  |  Print  |  Notify Moderator
This is a very good post because no matter what Park you go to always a problem with the Internet I know there is the exceptions I have something similar to the WiFi repeater here is the websitehttp://www.radiolabs.com/and it works fairly well but I see there is some good products out there I will be keeping a I on this discussion because we are always looking for something to help us thanks for a great post
frank-2
EVDOalex
Dallas, TX
Posted: 11/24/09 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
company i work for is now selling the pepwave surf as our "wifi as wan" solution.
with a tipsheet we've prepared, customers will find it easy to use campground wifi as an internet source for their cradlepoint routers (that have an ethernet port)
using the pepwave surf this way means no network settings have to change on any computer already associated with the cradlepoint router.
