RV.Net Open Roads Forum: Tech Issues: Ice on refrigerator blades... ?
 > Ice on refrigerator blades... ?
Tech Issues Related Tips
cannesdo
Presently in So. Cal.
Posted: 11/06/09 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
I'm in San Diego, a few blocks from the beach. It's not that humid but moreso than most places I've been. The center half of the blades are covered with ice. I have the climate control switch on. It seems like it's gotten worse since the weather cooled a little in the last few weeks. Should I have the low ambient on? It's only down to the low 50's at most at night some nights. Do I have to defrost my fridge?? Turn the setting down to 3 out of 5 and it's keeping at about 36 degrees but still I've got the ice.
Thx...
old guy
Oregon (pronounced Or e gun)
Posted: 11/06/09 10:06pm Link  |  Quote  |  Print  |  Notify Moderator
I read somewhere that a lot of ice build up is not good in RV fridges. I would do a defrost if it were me.
Dave H M
IL
Posted: 11/07/09 06:00am Link  |  Quote  |  Print  |  Notify Moderator
if the bsaldes sare just iced up, I don't see a problem.
If it is a solid pack of ice, then I would defrost.
JMHO
2yung2rtire
N. California
Posted: 11/07/09 07:46am Link  |  Quote  |  Print  |  Notify Moderator
Go to Ebay and search RV refrigerator fans. I installed one this year and in four months have not had any ice buildup. Keeps the fridge cooler too
suchristo01
San Diego, CA
Posted: 11/07/09 07:55am Link  |  Quote  |  Print  |  Notify Moderator
We don't use the climate control switch. Wired a computer fan, using an aligator clip to connect to the fin for ground, the other wire goes to the always hot side of of the interior light. I mounted the fan to the middle of the the bottom side of the top shelf. Never have a buildup of ice and never have defrosted other than to shut down for storage. Recovers faster and keeps the entire box at a more contant temperature. We also use a small dehumidifier to help through May Gray and June Gloom. Comes in handy around Houston when we visit relatives.
Tommy USMC,Susie USN Ret, Dog Buddy
2000 Fleetwood Flair 25F WH P32 7.4L 19.5"
2002 Ford Ranger XLT 3.0L 5 Spd Man
Blue Ox Base,Aventa II,4 PIN Locks
US Gear UTB, Power Gear Man Lev, Onan 4KW
Tent,GP Tent,Tent Trailer,2 Class A's
Are We There Yet?
dougrainer
Carrolton, Texas
Posted: 11/07/09 08:02am Link  |  Quote  |  Print  |  Notify Moderator
The Climate Control is for when the you have condensation between the OUTSIDE metal between the doors and this heat strip evaporates the water
The AMBIENT Control is for when the outside temps are lower and the items in the lower fridge (lettuce and such) get frost or freeze regardless of the temp setting or if you have a Auto temp refer, but other items stay cold. This switch leaves the interior light ON all the time and that small bulb heat keeps those items from freezing or frosting
MOST Dometic refers have NO WAY to remove the Ice build up on the evaporator fins, so you must do a manual defrost.
ANY ice build up will lessen the efficiency of the refer to cool adequately. Doug
skipnchar
Topeka Kansas USA
Posted: 11/07/09 08:34am Link  |  Quote  |  Print  |  Notify Moderator
Since you've already turn on the climate switch (supposed to remove excess moisture) then I'd guess you have a bad door seal gasket on the fridge that is allowing in more moisture than the heaters can remove. Ice is pretty NORMAL when it forms over a period of time (like a month or use) but if it's forming quickly there is probably a reason that can be corrected.
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
randallb
On the road
Posted: 11/07/09 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
Cann,
You do not say what fridge you have, so here is my .02. My Norcold iced up the blades when the thermister went bad. Since the thermister sent a warm signal to the control board the fridge ran all the time. The temps also dropped in to the 20's inside the fridge.
Hope this helps,
Randy
dougrainer
Carrolton, Texas
Posted: 11/08/09 09:58am Link  |  Quote  |  Print  |  Notify Moderator
That is not the function of the Ambient and Climate control systems. Read my post before yours. Doug
Deen
Vancouver, WA
Good Sam RV Club
Posted: 11/08/09 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
Defrost the refer, they are not self defrosting.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor and Recruiter
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
52nd yr of RV'ing
