RV.Net Open Roads Forum: Technology Corner: External DVD for USB and TV usage?
 > External DVD for USB and TV usage?
Technology Corner Related Tips
jcpainter
Crossville, TN
Posted: 11/07/09 04:59am Link  |  Quote  |  Print  |  Notify Moderator
Does anyone know if there is an external DVD player that can be used both with a USB connection to a desktop computer, then be removed and hooked up to a TV?
alcaudle
Asheville, NC USA
Posted: 11/07/09 07:13am Link  |  Quote  |  Print  |  Notify Moderator
I don't know, but it sounds like a great idea.
Alan, Donna & Savannah
klenger
Tucson AZ
Posted: 11/07/09 07:22am Link  |  Quote  |  Print  |  Notify Moderator
I doubt it. TVs are not computers and to the best of my knowledge, don't have USB ports that would support an external drive.
2008 Tiffin Allegro 32BA FRED Class A Motor Home
2008 Honda CRV, Blue Ox, SMI DUO Stay-in-Play Brake
jcpainter
Crossville, TN
Posted: 11/07/09 07:59am Link  |  Quote  |  Print  |  Notify Moderator
I should have been more clear. I meant a DVD player that had both a USB output and some type of TV hookup (HDMI, SVIDEO, COMPOSITE, ect.)
skipnchar
Topeka Kansas USA
Posted: 11/07/09 08:17am Link  |  Quote  |  Print  |  Notify Moderator
Well you COULD play the DVD on your comper and connect to the TV Via HDMI cable and display the picture on the television
2004 F-250 SCREW Long Bed (new)
OR 2004 F-150 HD (85,000 towing miles)
bcsdguy
California
Posted: 11/07/09 08:34am Link  |  Quote  |  Print  |  Notify Moderator
Check out this link
Audiovox
QMAO
Alberta Canada
Posted: 11/07/09 08:38am Link  |  Quote  |  Print  |  Notify Moderator
I have a small book shelf stereo with dvd,cd am/fm and usb input.
I have watched movies from the dvd and listened to music from the usb input but not sure if there is video support from the usb input?
I will have to put a movie on the usb memory stick and try it!!
1492
Virginia, USA
Posted: 11/07/09 09:10am Link  |  Quote  |  Print  |  Notify Moderator
As I understand, you want a PC external DVD burner for use with your computer, but with A/V outputs for direct connection to your TV? A few were available some years back, but were somewhat expensive. It would be cheaper just to buy a separate DVD burner for your pc, and a separate desktop DVD player for your TV.
The more popular route today are HDD Media Players. These allow you to use them like any USB external hard drive on your computer, then hook them directly to your TV to play back HD or SD(standard definition) video files, photos, or music files without the PC. These players generally have a variety of AV outputs including HDMI, and also come with a wireless remote. Many also have connections for portable USB drives and memory cards which allow direct video and audio file playback to your TV.
Clay L
Sioux Falls, South Dakota
Good Sam RV Club
Posted: 11/07/09 10:14am Link  |  Quote  |  Print  |  Notify Moderator
The world has changed when you and I weren't looking.
I was surprised to discover that my branny new 32 inch Samsung LCD TV has a USB input.
It can be used to connect to a flash drive. The drive can contain MP3 files, Slide shows, jpeg pictures, or firmware updates. There are menu options to play or view the various files.
Don't know about a DVD player though.
Clay (WA5NMR), Lee,(Wife) Codi, Brandi (Shelties) and Damncat (damn cat)
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
MrWizard
Van Nuys, Ca
Posted: 11/07/09 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
my TV has a USB port but it doesn't recognize flash drives, the port is there to hook to the PC and UPDATE the TV's firmware, maybe an update would add flash drive and Multi-Media support
however my new DVD player has up scaling and will play mpeg4 and Divx files directly from disc's, no need to convert them to DVD format
Connected via Verizon Via Motorola Droid with Android2 OS
